if evap has a small leak, what are side effects?
Old 12-29-2005, 03:46 PM
WS6FirebirdTA00's Avatar
Default if evap has a small leak, what are side effects?
i dont want to pay 80 bucks right now for a smoke test. the line and purge in the engine bay are brand new. the light comes and goes. i am thinking about setting the code to not report error so i dont have to look at the damn light. will it effect anything not being fixed?
p0442 small evap leak code
Old 12-29-2005, 05:24 PM
Moderator
jimmyblue's Avatar
This may be related to the fuel tank plumbing, a gas cap
that doesn't seal, or a fuel tank pressure sensor that's
being a whiner?
The idea of losing the entire contraption and putting a
breather filter on the flapping end of the tank hose, has
a certain rustic charm.
Old 12-29-2005, 05:31 PM
gas cap is brand new too so all the easy things are out of the way. lol
if it were you, would you just disable the code until you can find a fix?
Old 12-29-2005, 06:15 PM
Moderator
jimmyblue's Avatar
Yeah, according to the Helm book this is just a system
diagnostic. Though a big leak, might let enough air move
during (purge?) to alter low speed mixture. I'd kill the
code as prelude to bigger things.
Old 12-29-2005, 07:32 PM
Brandon Boomhauer's Avatar
why not completely take it off?
Old 12-29-2005, 09:08 PM
it is there to just vent the gas tank right?
Old 12-29-2005, 10:36 PM
SPEEDYws6's Avatar
It holds the gas fumes inside the canister when you turn off the car, and releases them into the intake once you get going down the road again. All it does really is keep the EPA happy, like said above, unless it is releasing these fumes at a low RPM it will have no effect on the vehicles performance.
Old 12-30-2005, 06:11 AM
and it could only release fumes low rpm if the purge valve had an issue correct? that is brand new so i know its ok
Old 12-31-2005, 12:16 AM
technical's Avatar
I remember back in 95-96 when OBDII first came out and we saw these codes repeatedly. The gas cap was one culprit. Overfilling the tank and/or filling with the engine running would also cause this code... you're not doing either of those are you?
And to answer your question, yes. The only way the evap system can purge (into the engine) is through the purge valve. Otherwise it would just leak into the atmosphere.
Old 12-31-2005, 06:59 AM
no i am not doing either
Old 12-31-2005, 01:45 PM
bullygoat's Avatar
Could be the vent solenoid has a small leak. I replace alot of those on different vehicles. Could be a hose clamp that didn't get tightened correctly. I'd take a look at the vent solenoid though, they have a tendency to leak some at times and not at others.
Tim
Old 12-31-2005, 04:14 PM
where is the vent solenoid?
Quick Reply: if evap has a small leak, what are side effects?
