ls1's top speed
ls1's top speed
I got a 98 trans am a4 and i had it up to 152 at the top of the third gear my buddys 01 ws6 six speed will bury the speed odmoter real fast like 160 +. I was wondering do any ls1 have any top speed limiters on them and if they do does anyone know what it is ir will they go till they run out of power
LS1Tech Administrator
Received 1,492 Likes
Originally Posted by ssrunner
Z28s are limited at 108mph I believe.
I can assure you, an LS1 Z28 does not shut down anywhere near 108mph.
It is whatever the pcm is set at. to a max of 255 mph. I don't even recall what mine was stock. Probably 155.
Perry
Now the real question is how fast will it go. And I don't know. But than again I only have 485 rwhp. So probably not much over 180.
Perry
Perry
Perry
haha... i like how you said you "only" have 485rwhp...
Originally Posted by 2K2WS6TA
If you believe Car and Driver, the top speed of a stock 4th gen LS1 F body is 162mph (they used a T/A for their test)
LS1Tech Sponsor
Yea same. I have the 3.23's in my A4. So your thinking i will run out of gear at 162 ish or will i be governed at 162 ish?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
1 Post
my friend has a z with 2.73 and at 155 his tach is almost at redline
so with a 3.23 i cant see how its possible to go 155 with the rev limiter.
only one way to find out
