Here's my self ported throttle body
Hendricks Machining Ported Throttle Body
I finally got around to porting my throttle body this week. I think it turned out well. I thought about epoxying the holes, but I didn't find what I was looking for to do it with, so I left it be. Took the pic with my cell phone, so it's not that fancy.
That's really good. The best thing is that you did the half-shaft mod. It'll really increase part throttle airflow. Now the air wont have to jump the "speed bump" going past the throttle blade.
Nice job.
I wish I knew what Shaner uses to fill the holes. My S-3 came polished inside and the holes were filled, he also used brass tubes set into the epoxy. Shaner has the best stock modified tb's in my book.
Nice job.
Originally Posted by slpss9723
how do you do the half-shaft mod, i've always wondered about that when i see ported TBs without that part of the shaft.....just never thought to ask until now.....
Just use a hammer to knock it out. Hit it on the side where the TPS goes (TPS removed of course lol). A washer will come out so dont lose it, its a pain in the a@@ to put the washer back on to but its possible. After you get the shaft out its much easier to work with too.
what are these mods you speak of half shaft and bump stop etc what do they do?Does this fix the problem when you hit a bump and they car acts funny ?
Also what is the benefit to porting the TB ? IS there a write up on how to do these mods ... porting the TB half shaft ET? Thank you !
i found this on a search a long time ago.... but i couldnt upload the zip so i just uploaded the site... (only 4.2mb an hour so if it doesnt work try again in an hour...)
http://geocities.com/tc3_002/
edit: dont bother clicking on any links as they wont work...
I replicated that into a webpage a while back with a few updates:
http://www.geocities.com/wilwaxu/throttlebody.html
