What size injectors do i need for 8-13 psi???
Just curious what size injectors you would recomond for a c5 stock 347, running 8-13 psi. I will be upgrading the motor soon so i dont want to max out the injectors, so i want some room to play. And what fuel pump do you guys feel works the best.
As has been mentioned, 60 lb injectors work very well, and will give you good part throttle driveability, and allow for room to grow.
Lingenfelters offer a drop in fuel pump for approx $300.00 or so, that works very well in the C5's. Bob
