Cam swap in a 02 z06..steering?
Does the steering need to come of if you're just installing a new cam? No oil pump changing, no timing chain changing, no dropping the oil pan, just pulling a cam out and putting a new one in.
thanks
thanks
I really didn't find it that bad. Go buy some vacuum caps and cap the lines when you pull them from the steering box. That way oil won't spill. I only lost about 2 tablespoons. Bungee the steering wheel straight and follow LS1howto. The lines can be gotten off from the top and the side through the fendor well. I though the mess the water pump lines made was the worst part of the whole thing. Good luck, it isn't really that bad.
