Tsp duals on LT1s
TSP Duals for LT1
Went to texas speed.com and was looking around and i saw the exhaust section then i wnet to True dual setups. I go clicking on that and it brings up more info about it, but in that info it says great performance for you late model LS1, and this kit is for 98+ LS1 cars. I found all this in the 93-97 LT1 section. Does TSP make a TD kit for LT1? I emaild Jon, but havent gotten a reply (its been 1 day, not a big deal) im just curios.
The LS1 cars driver's side header exits at an angle, and the TSP setup allows this.
Since LT1 headers exit straight back, the TSP setup would take some serious modification to make work.
Look in Summit or Jegs, they've got generic TD setups that would likely suit you better.
Originally Posted by 1993CaMaRoZ28ofIdAhO
Anyone modifyd the LS1 TSP duals to fit on the LT1? I was lookin into TSPs but know i hear they dont make them for the LT1s yet. Jon at TexasSpeed says there in the procsess. Anyway if anyone has modifyed them, how hard was it?
It might probably be easyer to modify your set of headers to fit the TSP X. The big difference between most ls1 headers is that the driver side is angled toward the side of the car, and lt1 long tubes point straight back. It would be interesting to see if the collector was cut and a small angle welded in how close it would be to fitting that TSP X.
