?? 9in. in lowered Z28 ??
Bought a Moser 9in. and did some searching and never found a straight answer for this.
I'm using eibach sportline springs in the rear currently and QA1's up front. I was told that a 9in. will not fit in a lowered car (would it the body), is this true. If so, what would it take to make a 9in. fit w/ approx. 2in's of drop? I'm using a BMR adj. torque Arm if that matters w/ a stock driveshaft.
Thanks
Thanks
Mine is not lowered and still hits on severe bumps. At first it hit on everything-- until it made enough room for itself. The problem area is the torque arm mount (Moser housing). I'd probably have to do some serious massaging to make it work if I was lowered 2 inches. Something to consider but not impossible by any means.
Originally Posted by Nittany_marine
My car is lowered, and my 9" will only hit on the severe bumps, while at speed. Not a horrible hit....more like a tap.
Originally Posted by RAIDER
Are all the pics on your cardomain after the 9"?
