Cam ?
Old 01-15-2006, 11:55 AM
99M6Z28's Avatar
Default Cam ?
I am working on a budget so I wanted to see what everyone opinion is. I want a cam but i know I need an intake and headers also. How much will I choke my cam if I do the cam first? I want a TR224/224 LSA114. Is this too much cam for stock heads and intake? Can I get buy with just headers? Or will I need headers and intake? Any help will be appreciated! Mods in sig
Old 01-15-2006, 11:56 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
LT's alone will help.
TR224 is a great cam for stock heads.
If you want a cam that's designed for stock manifolds, check out Thunder's CheaTR cam. Works great with stockers, and with Long Tubes.
Old 01-15-2006, 12:05 PM
02WS6Bird's Avatar
The stock intake is ok to go, the cam i am running in my camaro is much larger, and will be ok. It's not that the LS1 intake manifold is HIGHLY restrictive or anything, its jsut that it doesnt sned the airflow as directly to the heads. The stock heads will be fine on several if not all the cams out there really. I would spring for a set of lt's however,or run w/o a catback, just the cam exhaust manifolds and Y pipe... if you can gut your stock cats, that could help as a temporary fix.
Old 01-15-2006, 12:17 PM
!LS1 11 Second Club
Why run w/o a catback?
Old 01-15-2006, 12:26 PM
99M6Z28's Avatar
I already have an ORY-pipe so gutting the cats is out of the question. How long before I would be needing a tune?
Old 01-15-2006, 12:29 PM
!LS1 11 Second Club
Many guys put in a cam like the TR224 114 and get by w/o tuning. Tuning is always best for max. hp gains and the best driveability.
Old 01-15-2006, 12:36 PM
02WS6Bird's Avatar
free up some more exhaust flow
Old 01-15-2006, 12:39 PM
!LS1 11 Second Club
Borla.
Old 01-15-2006, 12:55 PM
02WS6Bird's Avatar
still none the less what flows better, catbakc or no catback...yeha borla is not restrictive, but the length of the tubes will most likely cause a big difference in flow
Old 01-15-2006, 01:00 PM
!LS1 11 Second Club
^ I think you're totally wrong.
Edit: I'll clarify.
I think it's impractical advice to tell people to drop their high flowing (hell, open plate is basically a cutout) Borla exhaust in search of a couple possible ponies.
Old 01-15-2006, 06:15 PM
99M6Z28's Avatar
I run an open plate but I do have the others if I need to change it
Old 01-15-2006, 06:40 PM
shackattack37's Avatar
i ran 12.73 on tr224 cam only 1989 iroc conv no headers
Old 01-16-2006, 04:13 PM
99M6Z28's Avatar
So, I don't exactly know what LSA means. should I go with a 114 or a 112 LSA?
Old 01-16-2006, 04:23 PM
!LS1 11 Second Club
From JRP's sticky:
C. Lobe Separation Angle (LSA)
- LSA is defined as spread in camshaft degrees between the intake centerline and the exhaust centerline.
- Overlap is the number of crankshaft degrees that both the intake and exhaust valves are open as the cylinder transitions through the end of the exhaust stroke and into the intake stroke
- LSA is ground into the cam and cannot be changed without grinding a new cam
- Bigger duration cams will have more overlap then a smaller duration cam even if both are on the same LSA.
- The key to making overlap work is maximizing the power in the rpm band where you want it.
- Long overlap periods work best for high-rpm power. For the street, a long overlap period combined with long-duration profiles combine to kill low-speed torque
- Reducing overlap on a long-duration cam will often increase midrange torque at the expense of peak power, but if the average torque improves, that’s probably a change worth making.
- Many enthusiasts purchase a camshaft strictly on the basis of how it sounds. A cam with generous overlap creates that distinctive choppy idle that just sounds cool.
- While doing my research on the T1 I cam across this dyno in which if I recall Tony (Nineball) stated that the blue graph was a T1 (112 lsa) and the other 2 where a B1 (114) lsa. 112 vs. 114
- What really affects where the cam makes the most power is the intake timing events. What affects drivability most is the exhaust-closing event.
