Some updated pics of my project
Well I got the car back from the shop who did my cage and I got done reinstalling the carpeting and finished up about 75% of the gauge installation (I've got 3 more to go where the radio used to be) and I've got to get wolfe racecraft door panels and carpet them.... I pick up my motor on Feb 14. I've got to wire the BS3 and rewire the car to an 8 circuit Pro Street switch panel from Painless.... So still a way to go but I should be ready for some mid spring dyno testing and NA passes.... N20 passes will be dependent on the results we get from the dyno.
Motor is a half filled LT1 383 w/splayed 4 bolt mains, Lunati Pro series crank, Oliver 6" billet rods, JE n2o pistons, 12:1 compression, secondstreetspeed large solid roller (Over .700 lift), Jesel 1.7 ratio shaft rockers, AFR 227 cc comp ported heads, Edelbrock Victor E single plane manifold, Big Stuff 3 standalone. ATI TH400 with 4000 stall ATI converter, Moser 9" 3.89 gears.... 2 stage nitrous kit 1 on plate, 1 direct port. 83lb/hr siemens injectors, etc, etc, etc....
Our target is 850RWHP on both stages of bottle (200/200). Car weighs 3200 with me in it so traction being good should be good for an 8.90 pass or so...
thanks man..... i've kept it on the low and haven't said much until I have an 8 second timeslip in my hands..... It's previous best was a 10.40@131 with a budget 355 and a 150 shot....
I want to see pics of the motor
Looks good man. I've got two words for you:
Wheelie bars
Wheelie bars
Beautiful! Thats all I can say
wow that looks awesome. the rear stance of that car will make the manliest of men cry home to momma.
hope all turns out well for ya
they look like weld draglites.
Hey whats kinda wheels and tires are those?
