oil cooler
Old 01-17-2006, 06:42 AM
RAO-3's Avatar
Default oil cooler
Anyone install an oil cooler on their LS1? I did a search, but nothing came up. I've been doing some research, but am interested to find out what others have done.
Ray
Old 01-18-2006, 11:14 PM
SSU's Drunk Typing Whore
Lithium's Avatar
TTT for you.
Old 01-18-2006, 11:55 PM
SUX2BU's Avatar
Before you put a cooler in, get an oil temp gauge to see if you really need a cooler. thats what i did. its not summer yet so i still won't know if i need one till it gets hot around here.
Old 01-19-2006, 06:11 AM
RAO-3's Avatar
My thought was to install the cooler with a thermostat in-line so that it would be used to cool the oil only when it exceeds the set temperature on the thermostat.
Ray
Old 01-19-2006, 05:54 PM
SUX2BU's Avatar
Ray
Yeah but how do you kow your oil is getting that hot. the avg LS1 driver doesn't need an oil cooler.
Old 01-19-2006, 06:27 PM
GR33N GoblinM6's Avatar
right.. the average one doesnt..
im so some road racing.. and will be using my LS1 for the 1st time this year. I would like to keep an eye on temps.
Old 01-19-2006, 09:38 PM
Teutonic Speedracer's Avatar
I've got one and it keeps the oil too cool if just driving on the street. I custom made it with my buddy for roadracing at the track. Let me know if you need to know more? My setup ran about $500-$600 in parts.
Old 01-19-2006, 09:56 PM
Moderator
jimmyblue's Avatar
There were some trucks that had factory oil
coolers. They used a special ($) plumbing
piece that bolts up where our cars have a
blockoff plate. Steel lines that slide on under
the exhaust on up to the radiator area. I think
this, with a thermostatic type trans cooler,
would be spiffy. But since I do not road race,
and am somewhat not in favor of adding a
new failure mode to the oiling system, I did
not go this way. A year or two back I posted
the part numbers, I don't have them on this
particular computer. The other option is one
of various remote oil filter kits, and put the
hoses to a cooler while you're at it.
I'd look at the Road Racing section for some
other perspectives on this.
Old 01-27-2006, 08:50 AM
2MCHPWR's Avatar
pics of my oil cooler install:
http://207.127.219.37/rx7mods.htm#oil
not needed for street. like tommy said, a must for open tracking. my oil pressure would get so low after 15 minutes of hard driving on the track in summer...oil got too hot - installed cooler and no more issues.
on street, in current setup, it is too cool - barely 160 degrees.
i have to update the parts i listed on that page because i didn't use a few of the parts (#6, #7 and #8 from HRP).
Here are pics i took when i first got the parts ( i did not use the T configuration). the LG billet adapter is sweet. the blue fittings in the pics weren't used because i put the big oil pressure sending unit in the stock location behind the intake manifold, and i just put the smaller oil temp sending unit directly in the LG adapter.
http://207.127.219.37/images/rx7/IMG_1844.jpg
http://207.127.219.37/images/rx7/IMG_1845.jpg
http://207.127.219.37/images/rx7/IMG_1846.jpg
http://207.127.219.37/images/rx7/IMG_1847.jpg
so here is the real parts listing:
from LG motorsports:
oil cooler adapter $99
HRP World: 1-866-851-RACE hrpworld.com:
Description P/N Cost Qty Total
1) -10 120º Reusable Hose Fitting FCM4044 $27.25 1 $27.25
2) -10 90º Reusable Hose Fitting FCM4034 $22.45 3 $67.35
3) -10 AQP Hose - .56 ID; .80 OD - per ft. FBA1000 $6.75 7 $47.25
4) AN-10 Adapter - Straight SETM22-AN10 $8.00 2 $16.00
5) 600 Series STD 19 Row Oil Cooler - 5 3/4" Tall SET619M22I $198.00 1 $198.00
from jegs:
1) 1/8'' NPT to M12 x 1.5 105-2277 $11.99 1 $11.99 - this is what the autometer oil temp sending unit goes into, which in turn goes into the LG adapter (but this had to be drilled out slightly so the sending unit would fit).
2) Radiused Pump Fitting. -8AN Port to -10AN Hose 555-100164 $12.99 2 $25.98 --this is what goes into the LG adapter
so that is about $500 plus shipping. not including gauges/sending units.
Old 01-27-2006, 11:59 AM
XJGPN's Avatar
Ray
I kinda went completely overboard with my setup. I did a Canton Oil Pan, (which comes with a remote filter adapter). I then plumbed that to a Canton Mecca oil filter, to a Canton Oil Cooler Thermostat and then to a Setrab oil cooler that is mounted behind the drivers side fog lamp on my 2001 camaro. All of this was plumbed with -12 Aeroquip stainless hose with either Aeroquip or Canton fittings. For a street car... especially one that is going to be run in the cold, you really want to either run a thermostat or one of the radiator/oil cooler combos (like what LG sells). The thermostat ended up adding roughly $350 to the cost of the setup between the additional plumbing and the cost of the thermostat itself. You can see a pic of how I located my oil filter and thermostat on the bottom of the following page (I'm currently selling my car.):
http://www.sfimotorsports.com/forsale/camaro.html
The bracket I made to hold the Thermostat was really easy to make and worked out really well. Had it powdercoated after fabrication and it made for a really clean install. Everything tucks in neatly right alongside/behind the fans.
Old 01-27-2006, 05:43 PM
Mine was modeled off of SS#670:
http://www.xse.com/leres/ss/oilcooler.html
I made a few changes. Link to some pictures of my setup....scroll down to the oil cooler:
http://www.geocities.com/teutonic_sp...s-winter05.htm
Good luck!
Old 01-27-2006, 08:09 PM
you guys are AWESOME!!!!
thanks for posting all these coolers.. this helped out A LOT!
Old 01-28-2006, 08:50 AM
Moderator
jimmyblue's Avatar
I got my files off the old laptop and these are the
truck oil cooler part numbers I have. There may be
a new non-obsolete replacement for the adaptor.
But if you can get something from LG then I bet
GM pricing would be no better.
Part # 15725587 Truck oil cooler adaptor - obsolete
Part # 15203890 Truck oil cooler adaptor hoses
Part # 15203889 Truck oil cooler adaptor gasket
Is anyone using the sort of thermostatic-byppass
trans coolers that an A4 would, but for engine oil?
Old 02-14-2006, 05:42 AM
Mine no longer clears my QTP headers. Looking for an alternate filter sandwich.
Old 02-14-2006, 09:17 AM
Moderator
jimmyblue's Avatar
That's where I think the truck setup would be quite
handy, it runs along the block behind the stock
manifolds (so should clear headers easily) forward.
Bet you could pick off a junkyard HD model for next
to dirt cheap, if you can find one with the tow pkg
wrecked.
Old 02-21-2006, 06:44 PM
Jimmy P's Avatar
Has anyone taken a look at the Thunder Racing oil cooler kit? Its prety simple in design, they just supply you with all the parts that are needed. I am wondering if I need one. I dont do any road racing, but with only 3 gears, a 3.73 rear end, and a soon to be a 4400 stall, the rpm's stay prety high when im on the highway.
Old 02-21-2006, 10:11 PM
That is using the canton adapter, but it doesn't show a filter relocation bracket, thermostat, or any angled fittings. The cooler itself looks rather large and oddly square shaped.
Side note, I did get my canton adapter to work with the QTP headers by having my buddy weld the one fitting on the side on about a 45 degree angle then pointing 90 degrees down.
Old 02-21-2006, 11:08 PM
SUX2BU's Avatar
Thats the reason i put a gauge on mine. i do 3,500 rpm's down the highway for almost an hour at a time, twice a day. So far the absolute hotest its gotten is about 220 with one fan on. and about 210 with both fans on. If it gets too hot during the summer i'm going to add a cooler. Or maytbe get an auto radiator and use the stock tranny cooler part for an oil cooler.
Quick Reply: oil cooler
