asp underdrive pulley
Old 01-19-2006, 05:30 AM
rs99z28's Avatar
Default asp underdrive pulley
does anyone know the length of the belt you need when you have an asp pulley installed?
the instructions that came with the asp gave me a gates part number but im looking to try a different belt. any help would be appreciated.
thanks
Old 01-19-2006, 08:52 AM
8GTOKLR's Avatar
Sponser ws6store has belt numbers or local parts stor should have conversion charts
Old 01-19-2006, 08:59 AM
777's Avatar
THUNDERRACING has them on their site.
Old 01-19-2006, 10:03 AM
Grimes's Avatar
Access. Belt #
11-755K6 (75.5 inches long, 6 rib)
11-770K6 (77.0 inches long, 6 rib)
11-760K6 (76.0 inches long, 6 rib)
The above are the belt numbers that thunder has on thier site. The belt part number is actually the measurement of the belt - gates uses similar part numbers on thier belts. So you can ask for a particular belt length by editing the part number/length.
Old 01-19-2006, 04:52 PM
blazinws6kush's Avatar
Napa Auto Parts sells Gates belts. I wanted a Gatorback but I heard Gates are good belts.
Old 01-19-2006, 05:32 PM
john5632's Avatar
any charging issues,lights dimming etc. with those UD?
Old 02-25-2006, 02:05 PM
Jimmyz's Avatar
thanks
Just spent the morning (mainly running around to get the belt) doing this on my 383 LS6. I got the belt from AutoZone, Goodyear Gatorback Part # 4060755 is the one I used as it was the shortest. The 4060760 fit fine but I could see how that would flip off under hard acceleration.
Jim
Old 02-25-2006, 06:42 PM
LS1TECH.com Sponsor
WS6store.com's Avatar
The 755 is advised to be used unless you have an adjustable tensioner. The 760 often works its way off of the tensioner by a rib or two and with time will eat away the edge of the belt (unless you contantly check under your hood and put it back). Going with the 755 eliminates that. We suggest Goodyear Gatorback Belts as replacements.
__________________
WS6Store.com | Sales@WS6store.com
F-Body Performance Parts | 1-877-232-9701
Old 02-25-2006, 09:49 PM
BLK02TA's Avatar
WS6store do you offer the belts with your pulleys?
Old 03-09-2006, 06:11 AM
rs99z28's Avatar
i just used Part # 4060755 and it wouldnt fit cause of my adj tensioner. so im assuming the 760 will be fine?
Old 03-09-2006, 08:30 AM
Jimmyz's Avatar
Yup...4060760 should work just fine.
Jim
