True Duals?
the bassani that i have on both cars hook to the factory cats. have some pics
http://www.stealthram.com/bassanidualexhaust.htm
You can have a custom set-up made and when you do LT's, you can just modify the duals to hook into the headers. Cheaper than anything to have a custom kit made IMO. I paid $475 with mufflers and H-pipe to run all the way out the back. It is tailor made for my car and tucks up better than stock exhaust did.
Yep. When I first had them put on my 02 Z I had the manifolds on it. I had them dumped before the axle.I supplied the mufflers and x-pipe. A $100 bill later and I was on my way
Bassani
What does the Bassani kit run? I couldn't find it on their website just now. How does it sound? I used Bassani on 5.0 stuff in the past, and it was quality stuff. Who can do custom work in the DFW area, and can I install the Bassani system at the house? Your system looks like a factory item! Thanks for ALL the help!
Im sure some of our sponsers in the Texas area would help you out in making a true dual system (Texas Speed would probably be a good bet and their Rumbler system is very popular).
You could do it at your house if you had enough room underneath to work with along with the necessary tools.
stainless steel = 949.00
aluminized = 779.00 through vinci high performance where i got mine for both cars.
yes, you can install it in your driveway. click the 00 formula link to see how it bolts to the stock cats and runs under the car.
sound clip of the 00 formula
wife's car with vinci 062 cam.
rev in park
idle in park
idle in drive
