Bad Cat/s??
Bad Cat/s??
I don't put a lot of miles on my car but the other day when I started it I heard this faint rattling noise........over the course of the next 36 hours it has grown to a full blown ugly sound, similar to a pebble rattling around in an empty coffee can or what it might sound like if my heat shields were rattling against something.......but since I don't have those on there anymore, I know it isn't that.
I can barely hear the sound when I pop the hood and try to listen but it does get very loud when I walk around the car and get to about the middle of the car, driver's side back to the left rear wheel well.......someone suggested that my cat went bad. Any other suggestions or agreements with that one?
Also the sound does NOT change or get better or worse with a change in RPM, I usually hear it most upon initial start-up and at idle at a stop light or as I am just taking off in 1st gear, etc. I can faintly hear it while I am driving (most of the time) but it seems to be at it's worst when I start up the car.
TIA.
TIA.
Muffler Bearings?
Sounds like a cat to me. If it was piston slap (or other engine problems) you'd hear it more when you opened the hood. If it was the exh hitting, you hear it worse when you let the clutch out
Originally Posted by WAHUSKER
Muffler Bearings?
Originally Posted by TwoFast4Lv
Yeah deffinately the Muffler bearings man
From what you are saying it sounds like a cat. You have stock exhaust? If so I have a cat
But thanks just the same.
Originally Posted by Ackattack1
yeah, if they're scrapping, that may have been the cause.
Originally Posted by Poik
The fix for the problem is a trusty crow bar and about 15 minutes
Originally Posted by Racehead
With the car turned off take a rubber mallet and bang on the cat. That'll tell you much
Seriously, thanks, I will put her up on the ramps tomorrow and see........it was weird, when I went to the gym today......no noise at startup and almost no rattles at all the entire trip.......coming home was a whole other story though...
