My new 100mm throttle body
Originally Posted by GuitsBoy
LOL!!!
What are you going to use for the shaft and blade?
Ill post progress soon as I get my CAD finalized.
Originally Posted by Lasershop
Shaft, drill rod steel. Hardened after machining. Blade solid brass.
Sounds good. What intake manifold are you gonna use?
I had often though about CNCing out an adapter or a full throttle body that has a large 90mm or so blade, but then tapes down to 78 behind the blade. The theory being that with the blade shaft not being an obstruction at the 78mm bore, it should flow much higher. Maybe you could taper the rear portion down to fit the 90mm intakes.
Originally Posted by 777
He owns his own shop. He uses lasers, hince his user name. It's also his shop name IIRC.
Judging from his site, I think the laser is used more for plastics, laminates and other meltables. I have a sneaking suspicion he's got a CNC or two hiding somewhere in his shop though. Nothing wrong with milling them out the old fashioned way, but id be DAMN impressed to see a beam of light cut through 4 inches of aluminum and then stop before going right through (ie mounting flange).
If he's gonna cut through that block with a laser!
Old Bridgeport V2XT CNC. My favorite toy. Been broke down for about 8 months and I just got it fixed $$$$. Just use it for in house repairs and stuff like this. Lasers cut plastic for a living.
Life would be much less complicated and time consuming by just making a thin adapter to mount a 90 or 105mm Accufab 'Stang unit. They can be found polished for $200.
Of course, if your objective is simply custom/'one-off', to ya...
Well......... I was nearly done with it. Our digital camera has seemed to walk away. Anyway.. then I started thinking. Why not, say.. 200mm. Its nearly done and probably not what you might think. Does not look like a coffee can. Stay tuned (for whoever gives a crap). Pics soon.
Originally Posted by NLang
200mm? Why? lol That's beyond over-kill for even the largest ci LSx based engine available.
Why go half-way with four units when you could just make a much more beneficial individual runner system (individual intake runner and throttle body per cylinder). It'd be even more 'sweet' looking, I might add
