112 LSA on Automatics??
the transmission doesn't have any correlation to the cam you run, other than the fact you'll need an aftermarket stall to run a significantly larger cam, and a set of rear end gears. think about it, old muscle cars ran 3 speed automatics with cams on 106 and 108 lsa. what cam are you looking into?
Originally Posted by MattZ28
What the hell are you talking about?
Got vague?
Got vague?
I am just begining to learn the real in depth stuff on cams and really hope SStrokerace or the like pop in on this question.
i just heard a rumor 114 LSA is better with an auto then a 112 *used for m6* i just heard the powerband for it would be completely different, and i dont wanna do a stall at the moment either
Internet Mechanic
Take the same duration and lift and put a 114 against a 112 LSA, the difference will be loss of torque from idle until about 3500 rpms. 114's are for boost applications.
112 and lower are great for N/A (as long as you got the compression). its compression that makes power.
As for nitrous, stick with a grind that your going to run most of the time with, 112 would be fine.
Before GM-847s became the hot-item like Hotcam did years back I installed the 847 on my stock cubed (6spd) but found several who also installed it on their (auto) with great results. It's a 112lsa straight up install cam from Crane with great results, like the Comp-306 and some similar others. The difference between 112 vs 114 in an auto I don't think is major for track performance E/Ts especially in a mildly modded car.
good luck
good luck
