Race Gas 103 oct. on Stock Motor
Old 02-02-2006, 06:43 PM
TonyP187's Avatar
Default Race Gas 103 oct. on Stock Motor
I have a 96 Trans Am with some mods unknown to me a raced an evo 1 and I beat him once and he beat me once both, were unfair races but real close, Im going back tommorow to race him again. I wanna make sure I win, is it ok to use race gas in my motor?
Is there any other things that I could do to make my car faster for one night?
Old 02-02-2006, 06:52 PM
94greencamaro's Avatar
I dont see how race gas is going to make your stock motor any faster
Old 02-02-2006, 06:58 PM
transam5.7lt1's Avatar
It should make more power....
Old 02-02-2006, 07:03 PM
TNMuscle's Avatar
on some motors it actually sometimes hurts the motor more than it helps
Old 02-02-2006, 07:06 PM
Renegade's Avatar
I wouldn't think you would need it to take an Evo, my car is mainly stock... but I took an 04 Evo twice. Maybe I was just lucky at the time, justbe careful racing on the streets. When race, we go out into the country, late at night with minimal chances of seeing other cars, and we have people at the end of the course to make sure nothing is inbetween us at all.
Old 02-02-2006, 07:11 PM
State69champ's Avatar
I raced a modded evo and he only had a half car on me... from 20-100...
Old 02-02-2006, 07:22 PM
TonyP187's Avatar
So you guys dont think I would get any gains? I heard if I advance the timming when using race gas it helps alot, But do I need a programmer to do that?
Old 02-02-2006, 08:32 PM
slowmofo's Avatar
just take everything out of your car, spare, jack, rear seats blah blah. loose some fat and you will gain more then you would with race gas..
Old 02-02-2006, 08:44 PM
kozak's Avatar
race gas usually on works good with worked motors.
Old 02-02-2006, 09:00 PM
96capricemgr's Avatar
Please explain exactly how it would make more power?
That said you are wrong. Injuneer on the other board with a BUILT motor did a lot of dyno testing with full tuning and stopped gaining power at 94 octane. If there is no knock retard more octane will gain you nothing. As far as advancing timing a "programmer" is the wrong way to go about this. Get custom tuning like pcmforless, Ed Wright or madz28.com for 91-3 octane whatever you have local.
Depending on the exact race gas you could destroy the O2s and cats, they don't like lead.
Now with a built race motor higher octane can help you make more power but it IS NOT due to the octane, it is due to the compression you can run without detonation with that higher octane, that is why race gas on a stock motor is pointless.
Old 02-02-2006, 09:56 PM
TonyP187's Avatar
thank you
Old 02-02-2006, 10:04 PM
hashtagBMW
Speed Density's Avatar
I wouldnt go over 93 on a stock motor. Even using octane boost is ify.
Old 02-03-2006, 05:24 PM
GIZMO's Avatar
There is a lot more to race gas than octane and detonation. I have seen major gains and losses from one brand of gas to the next at the same octane rating. Why do you think that they have fuel checks at sanctioned races?
Daren
Old 02-03-2006, 06:07 PM
That is true but fact of the matter is still octane only helps if it is needed to keep detonation at bay.
There are several different chemicals they can use to up octane a few of them commonly available as "paint thinners" and are mid 11X range for octane, wouldn't run them alone but can be blended with gas IF you need more octane, pump gas can even contain some depending on what local regulations are.
Old 02-03-2006, 06:55 PM
Well, there was a 2002 Ford Lightning at our local track that improved 1/4 mile times just by switching to 103 octane. I can't remember the exact time it was running, but it was constant until the switch to 103, which I remember cut the time by .35 on several passes... Common sense tells it did improved its power band....... Truck is stock except for exhaust... 5.4L SC....
Old 02-03-2006, 07:24 PM
GXP Lover's Avatar
Quite honestly, it would make sense a blown motor would benefit more from race gas. With a blown motor knock retard is fairly common at wide open throttle. In a N/A, it's less common but obviously can occur.
Old 02-03-2006, 09:32 PM
Fresca4u2's Avatar
Default 104 Octane in a nearly bone stock 96 TA
In a way I can agree with race fuel being needed for a built motor, but hey, guess what, I ran 104 Octane in my 96 M6 TA and saw great improvement. Yes detonation is kept at bay by the PCM, but it does this by retarding the timing, which does what? Makes you lose power!!!!!!! If your car is running hot, or it's a hot day, it's more prone to detonation and the higher octane fuel is going to help keep the PCM from having to retard your timing. It's a little expensive, but it's worth it in the long run for the few extra ponies you'll get out of it. I think I paid like $5 a gallon for it about 2 years ago so I'm sure the price has gone up since then.
Old 02-03-2006, 10:23 PM
There was a complete study about acetone as a fuel additive... it was mentioned in that study/article that acetone would also raise Octane points, plus give off a cleaner burn, being cleaner to the air and emissions. Sorry for getting off topic.....
Old 02-03-2006, 10:26 PM
Fresca4u2's Avatar
I think I remember reading an article about that too, problem there is that a gallon of acetone is like 7 or 8 dollars :S Of course, I guess you could put 1 gallon of acetone to 5 gallons of 91 octane pump gas and probably bump your octane up to over 100.
Old 02-03-2006, 10:33 PM
But the ratio to use is small...... 2 to 4 ounces of acetone per 10 gallons of gasoline.
Quick Reply: Race Gas 103 oct. on Stock Motor
