Air Bag Light!!!
Old 02-04-2006, 05:39 PM
frisky2101's Avatar
Default Air Bag Light!!!
okay so I go ta new camaro cluster and I hook it all up and the damn Air bag light stays one how do i get rid of it?
Old 02-04-2006, 08:03 PM
2002_Z28_Six_Speed's Avatar
Could be two things:
A: The cluster is not fully accustomed to the car. Can fix this is a Tech 2, or turning the car on for 30 minutes turn it back off for 5 minutes, turn it on for 30 min, off on off on off on. Keep doing that for like 5 or 6 times and it will allow everything to communicate without a tech 2. Don't start the car, just turn it to the on position.
Everytime my dealership tells me I need a tech 2 for something I find a way around it! $%^#$ them!
B: There is a wiring problem. Common trouble spots? Ummmm check the clockwork spring to make sure it has continuity. Also make sure the connectors are actually plugged in.
I am betting your problem is A.
Old 02-05-2006, 02:17 AM
frisky2101's Avatar
thanks I'll try that tomorrow
Old 02-16-2006, 01:05 PM
Michael55123's Avatar
Did this work for you? I can't get my damn air bag light to go off after my cluster reas replaced. I have hptuners, but don't think I can do a thing with it. Any ideas?
Old 02-17-2006, 12:22 AM
HP Tuners won't fix it.
Old 02-17-2006, 03:58 PM
frisky2101's Avatar
never got the chance to find out, put the stock cluster back in until the new overlay comes in
Old 02-21-2006, 11:11 PM
Well hmm, any ideas? Anyone?
Old 02-22-2006, 01:49 AM
frisky2101's Avatar
still haven't got the new overlay in yet been to busy working on everybody elses car
Old 02-22-2006, 04:27 PM
Derek_02's Avatar
I'm having the same problem too. I'm gonna try the tech 2 tomarro hopefully, and i will let you knwo if it works.
Derek
Old 03-21-2006, 01:01 AM
TTT anyone, please? This is damn annoying
Old 03-21-2006, 09:54 AM
rtr2001ss's Avatar
Air Bag fuse, maybe?
Old 03-21-2006, 11:33 AM
Derek_02's Avatar
I hooked up the scan tool and i gave me 5 different codes but it would allow me to turn it off. You should try and do the same. My father is suppose to look up the codes at work for me so i can figure out what i need to fix it. Ill keep you posted.
Derek
Old 03-21-2006, 05:09 PM
what are the codes if you know them off hand?
Old 03-21-2006, 08:25 PM
Derek_02's Avatar
b0017-pass front deploymernt loop open, b0026-driver front deploymernt loop open, b0051-deployment command, b1001-option configuar error
Derek
Old 03-22-2006, 07:37 PM
Sounds like your clockwork spring is bad.
I had the BTC for driver's loop open. Replacing the CW spring did the job.
Does it make any clicking sounds from the columun when you turn it from lock to lock?
Old 03-22-2006, 08:02 PM
usnzulz's Avatar
Yes I will second that sounds like the clock spring. Work with them all the time.
Old 03-22-2006, 10:18 PM
quiksilver9531's Avatar
The air bag light came on with the new cluster because----
Instrument Panel Cluster Synchronization
When installing a new IP cluster it must be synchronized to the supplemental inflatable restraint (SIR) module in order to synchronize the new cluster, perform the following steps:
Connect the Scan Tool to the data link connector (DLC).
Proceed to the SPECIAL FUNCTIONS key under INSTRUMENT PANEL CLUSTER.
Select the SYNCHRONIZE IPC and SIR key.
The screen will display: IPC and SIR modules-Now synchronizing modules.
If the procedure is completed successfully the screen will display: Module Synchronization Complete.
If communication is lost with the SIR or IPC, the screen will display: Loss of Communications with Vehicle - Check Diagnostics Link Connector - Check Ignition (On/Off).
Old 03-22-2006, 10:19 PM
Don't try to fix them either. Tried that with limited success. It is a non-serviceable unit.
Old 03-22-2006, 10:20 PM
If the light wasn't on before the new cluster and it went on after the new cluster was put in then its because the new cluster isnt synchronized
Old 03-22-2006, 11:43 PM
Maybe you are right, but something is bothering me...
If it hasn't fixed itself by this many ignition cycles then something else might be wrong. Mine fixed itself in a couple of hours from turning the car on any off. This guy has been trying to fix it for a long time.
Plus why is it throwing an open loop code?
I just thought, he might have done some mods to his car and broke the coil. We may never know.
Quick Reply: Air Bag Light!!!
