Who has a 3” catted Y w/ good ground clearance?
I am still trying to get a handle on the tradeoff between a better flowing exhaust and ground clearance. Do you have a catted 3” Y-pipe that provides good ground clearance? If so, who made it? If it is custom, what cats did you go with? What is your clearance, and is your car lowered? I am leaning towards QTP headers, but please feel free to reply even if you are using another brand of headers. Thanks for the feedback.
I have QTP headers and Y-pipe they clame on teh y that you can get it up about 1/2 inch from the body witha bit of work but i could get anywhere near taht so i went and had a pipe bent to replace one of the otehrs not it fits in there witha 1/2 inch easy so i recomend the QTP catted y
If you're at stock ride height you'll be ok. Bullet cats like the random technology 7000's tuck about the best. slpss9723 modified his QTP Y to fit and it's one of the cleanest installs I've ever seen on an f-bod. Sounds mean as **** too! https://ls1tech.com/forums/generation-iii-external-engine/358241-qtp-lt-s-catted-y-pipe-question.html
I thank everyone for their replies. Special thanks to weestro for the link. That was very helpful. My LS1tech searches only yield year 2006 results, so I may have never found that one.
If I decide to go the route of a custom Y, do you think it necessary to use a specialty shop, or do you think I could get good work out of some franchise shop?
franchise shops usually don't like to do custom work and charge a hell of alot more than a specialty shop...or they sacrifice quality to get the job done
FYI my TSP Catted Y has no clearance or banging issues on my car (even over speedbumps and driveways with sharp inclines) - stock ride height
Originally Posted by Cyborg
I have in my basement my old SLP 3" catted Y- it hung low but after about 10K miles it was nicely clearanced
I'm in the same boat...
Originally Posted by y2k_ta
My SLP 3" Y-Pipe doesn't give me any troubles. I've never had any trouble with it hitting the floor either. My car isn't lowered, which makes a big difference. I'm also running SLP LT's & Speed Inc. Off Road pipes. It's all welded up, so it's not going anywhere
...I wonder if the skid plate from my Jimmy will bolt on my TA
[EDIT] added pic of "clearanced" SLP LT's...
Originally Posted by bitchncamaro
MY kooks catted y-pipe has more ground clearance then my stock setup.(becase its almost on my floorboard) With my slp SFC u cant see anyting
James
I realize this is a 3+ year old thread, but to answer the O.P.'s question...
I have a Jet Hot Modular Y-pipe that has very small Bullet Style Cats. Or I can remove the cats and run "Test Pipes" in their place to make it an ORY.
It has about the best ground clearance of any Catted Y-pipe I've seen. This is due to the fact that the cats are so small and are simply placed inside a flare on either side after each collector and then a 3" wide Band Clamp is used to seal the connection around them.
The only down side to this Y is that its not Stainless Steel and it doesn't have the best merge. But other than that, I'm very satisfied with mine.
I'm not sure if they are still available through Jet Hot. I purchased mine from the WS6Store in January of 09. I believe I received one of the last ones then.
The WS6Store did have an identical one for sale, not under the Jet Hot name, for the longest time, but I can no longer find it on their website. So they may be entirely extinct.
