Control timing with Delteq
Old 02-11-2006, 11:14 PM
garth285's Avatar
Default Control timing with Delteq
Sorry if this has been brought out before but Im gettin mixed results when finding topics on this and hard to find a good solid post about using som sort of MSD box or somethign to control (advance or retard) timing.
I plan on spryain a 125 or a 150 shot soon and atleast want to mess with the timing so I dont go BOOM! so fast lol....
so What kinda systems coudl I look at to control my ignition for timing?
Thanx in advance - GArth
Old 02-12-2006, 07:14 AM
dhdenney's Avatar
MSD DIS-4 but you will have to buy 4 interface modules also made by MSD. I can find a PN for you later if you like.
Old 02-12-2006, 08:53 AM
383LT1S10's Avatar
I amgoing to run the MSD +4 here as well. The modules run like $30 a piece. I have used the +2 on a V6 and the difference in performance and all around running was great! They are very flexible systems.
Old 02-12-2006, 09:48 AM
96capricemgr's Avatar
Do NA timing in the computer ONLY use aftermarket boxes to retard it for nitrous not to advance it. make sure you get someting with a rev limiter and window switches too.
Old 02-12-2006, 10:36 AM
garth285's Avatar
cool, so this is basically what I need correct? http://store.summitracing.com/defaul...6&autoview=sku
and jsut the 4 extra interface modules?
Old 02-12-2006, 11:23 AM
dhdenney's Avatar
These are the modules http://store.summitracing.com/partde...5&autoview=sku
The DIS-4 has timing retard and a rev limiter and I also use an MSD window switch for activation and shut down.
Old 02-12-2006, 11:48 AM
garth285's Avatar
nice, thanx dude!
Old 02-12-2006, 01:23 PM
SRZ
SRZ's Avatar
In the process doing this myself. It's not cheap I tell you. Don't know why exactly why you can't use the Delteq coils and having to use these instead. MSD coil
Old 02-12-2006, 02:00 PM
garth285's Avatar
well those go inbetwen the coils correct? and u use stock delteq coils? Those are jsut to control to coils right?
also anyone who has set this up, got any pics or wiring diagrams, intrested in seeing how this would work
Old 02-12-2006, 02:13 PM
383LT1S10's Avatar
Yeah those go between the coils and the module. Basically all the module will do is provide the volatage for the coils. You can use Delteq coils but MSD ones work better.
Old 02-12-2006, 03:54 PM
dhdenney's Avatar
I was not aware that MSD made two terminal coils for this setup?
Old 02-13-2006, 11:58 PM
95 TA - The Beast's Avatar
For pics of that exact setup:
Delteq Stuff
Old 02-14-2006, 12:16 AM
96silverram's Avatar
I'm in the process of doing this to my Delteq setup right now. I have everything except the MSD DIS 4, which I will have shortly
Parts needed:
1. MSD DIS4 #62152
2. MSD 8870 (need 4) coil interface modules
3. MSD 8912 (need 2) tach interface (you could take the white lead,PCM)
4. MSD 8224 (need 4) worth the upgrade, but you don't have to use the MSD
This setup will cost quite a bit over the price of the DELTEQ setup, but you will be happy
Quick Reply: Control timing with Delteq
