Has anyone here have upgraded front 13inch. rotors??
I found a palce that sells a kit here on ls1tech, they are oine of the sponsors. They have a bracket that lets you put the c5 calipers on the camaro and you use the c5 rotors as well, heres a link bud http://www.umiperformance.com/c5conv.aspx
I've done the Wilwood 6 piston setup with 13.15" two piece rotors. I used a 98-02 setup on my 96 WS6 and replaced the front spindles with 2002 units and brand new GM hubs and pretty much everything else you can replace on the front end
![](https://i5.photobucket.com/albums/y194/96SilverRam/DSC01190.jpg)
![](https://i5.photobucket.com/albums/y194/96SilverRam/DSC01317.jpg)
![](https://i5.photobucket.com/albums/y194/96SilverRam/DSC00943.jpg)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](https://i5.photobucket.com/albums/y194/96SilverRam/DSC00965.jpg)
Actually, the Baer and the Wilwood setup should just bolt onto a 98-02 LS1 spindle without having to do all the cutting to the spindle. The Wilwood kit was super easy to bolt-on to the 98-02 spindles for my LT1, no cutting. I don't know on the corvette setup if there is anyway around having to cut your spindles (LS1 or LT1) to get the vette kit to work ?
Thanks, Pipes !
Thanks, Pipes !
I don't understand how people can keep their engine bays/under the car so clean! The headers still look great. I have put on about 10k miles on my headers and they are starting to rust just a little.
