Can traction control be add added?
Old 02-13-2006, 12:51 AM
wrench's Avatar
Default Can traction control be add added?
If it did not come factory equipped can it be added?
Old 02-13-2006, 08:15 PM
pontiac's Avatar
think you have to have different computer and wiring.
but I have it and wanted it
but never use it ecept it did get me out of the mud once
Old 02-13-2006, 08:32 PM
CW00BlackTA's Avatar
Not worth the trouble. You can learn to drive without it and do just fine. I've permanently disconnected mine. If the rear wheels start to spin, lift off the gas.
Old 02-13-2006, 09:07 PM
j3ff's Avatar
i also have disconnected mine, it really didnt help at ALL......
the car is more fun to drive without it......
Old 03-01-2006, 05:45 PM
ls1xpreSS's Avatar
I agree!!
Old 03-01-2006, 09:23 PM
DesertFox's Avatar
I think the wires are there, but the rear end has some extra stuff (for sensors?) that might make it more trouble than it is worth. Plus the stock traction control really sux, consider yourself lucky that you don't have it. I do.
Josh
Old 03-01-2006, 10:11 PM
2002_Z28_Six_Speed's Avatar
You need the rear exicter wheel that goes in the axle. Probably also need the entire wiring harness for the car. Or if you are smart you could compare the differences and rewire your own.
Old 03-02-2006, 11:17 PM
hondo's Avatar
You can have mine, I never use it
