6l80e available for our fbodies?
Racer
Does anyone know if the 6l80e in the 06 vette is or will be available to use in our fbodies? And if so what is the power capability,for instance, is it as strong as the 4l80e? Would a 4400 stall work with that 6 speed auto?
Originally Posted by SVTKILLER
how much can i get a 4l80e for? And where,i cant seem to find ANY! Thanks
https://ls1tech.com/forums/automatic-transmission/451736-any-4l80e-builders.html
Racer
Originally Posted by da wrench
Check this thread....
https://ls1tech.com/forums/showthread.php?t=451736
1 Post
4L80e's can be found in HD trucks.... 3/4 ton, and 1 ton trucks...
4 = 4 Forward Gears
L = Longitudinal Mounting
80 = Series of transmission (60 is a moderate duty, there for the 80 is HD hince why
it's found in HD applications)
E = Electronically Controlled
4 = 4 Forward Gears
Restricted User
Interesting break down of the nomenclature, however I thought the 80 (or 60, 65) portion was relative to the input torque rated? Hence 4L80E was 4 speed, Long. mount, 800ft lbs torque, Electronic? With the intro of the 4L65E which provide a bit more holding power, then again, 5 could be for the 5 planetary gearset used over the conventional 4?
According to GM, the torque rating has nothing to do with anything. It is just a reference number indicating that it can hold more power. The 60 series can hold about 400-450, the 65 can hold 450, the 70 can hold a tad more, and the 80 can hold 500 or so. There is no direct correlation between the series number and torque capacity.
1 Post
The 4L60e only has 2 planetary sets, with 3 pinion gears or "carrier" gears....
L is for Longitudinal, where as FWD have a T for Transversly mounted
the 60 is just the series of it, it has nothin to do with actual TQ holding capacity...If it were that would then people with strokers wouldn't be ripping them out for a 350/400 setup...They would just go with a perf. build 4L80e....Cuz not too many streety cars, or cars on this site are making 800 lb/ft of tq.....
The reason why the tranny has 2 sets of planetaries are, because it is cheaper than having one, and having to engineer something to disengage something, and engage another part inside the transmission so having 2 set sof planetaries allows the transmission to have less parts, and be more compact...If you understood how planetaries worked, you would scratch your head at first as to why it's a 4spd, because out of one planetary gearset in the 4L60e you can get 5 forward gears, and 2 reverse gears out of it...confusing but if your in an ASE Tech Certification program, it is easier...
4L65-E planetary carriers each have 5 pinions.
1 Post
No, not necessarily....All we have done for the past 2 weeks is tear down 4L60e's, not one of them have had 4 pinion gears, all the one's I've done so far have been 3....You can buy aftermarket planetaries that have more gears for strength...Not sayin there might not be, but Factory GM Teardown manuals state there are 3 pinions...
They're supposed to have 4 pinions per planetary gearset.
My GM Unit Repair Manual shows 4 pinions.
My Hydramatic 4L60E Technician Guide shows 4 pinions.
1 Post
The 4L80e is a waste....you can build a 4L60e to handed anything that the car will throw at it, and have the holding capacity of the 80 series, and still have money in your pocket when it's said and done...Plus no where near the roatational mass of the 80 series either, a 4L80e can be picked up for $2500-$3000 probably...this is coming from me, as well as an ASE Master Certified Tech who is a Master GM Tech as well....The 4L80e is the heaviest 4spd trans there is, and their 4T80e transaxle IS THE HEAVIEST hands down, only found in Lac's with the V8 FWD, and the Old's Aurora....
Anyone who's been in the 4L60e knows the weak area's the Reaction Sunshell, and the sprags are the weak points, both of which have aftermarket counter parts avail....then if you want you can get beefire planetaries as well...
As for the planetaries I will see what I Can come up with, I am doin Transaxles now, THEY HAVE 4 pinion gears lol 3T40 yay!!!
I agree, a stock 4L80E is quite expensive and you can build a (or buy an already built) stong 4L60E for less money;
and the 4L60E lighter weight is good too as is the steep first gear ratio.
LoL... yeah, I was surprised to find 4 pinion planetaries in my old car's 3T40/125C.
Cheers
Joe
Cheers
Joe
1 Post
Hey Joe, care to chime in on this thread with this guy cuz he clearly is arguing the opposite with me...
https://ls1tech.com/forums/showthrea...18#post4303018
Right out of the book!
(661) Output Shaft to Input Carrier Retainer
(662) Input Carrier Assembly - 4 or 5 Pinion-Model Dependent
(663) Thrust Bearing Assembly - Input Carrier to Reaction Shaft
(664) Input Internal Gear
(665) Reaction Carrier Shaft Front Bushing
(666) Reaction Carrier Shaft
(667) Reaction Carrier Shaft Rear Bushing
(668) Reaction Shaft/Internal Gear Retainer Ring
(669) Thrust Bearing Assembly - Reaction Shaft Shell
(670) Reaction Sun Shell
(671) Reaction Sun Gear Retainer Ring
(672) Reaction Sun Bushing
(673) Reaction Sun Gear
(674) Thrust Washer - Race/Reaction Shell
(675) Low and Reverse Roller Clutch Race
(676) Low and Reverse Support to Case Retainer Ring
(677) Low and Reverse Roller Assembly Retainer Ring - Cam
(678) Low and Reverse Roller Clutch Assembly
(679) Low and Reverse Clutch Support Assembly
(680) Low and Reverse Clutch Support Retainer Spring
(681) Reaction Carrier Assembly - 4 or 5 Pinion-Model Dependent
(682a) Low and Reverse Clutch Plat - Waved
(682b) Spacer Low and Reverse Clutch Plate - Selective
(682c) Low and Reverse Clutch Plate Assembly - Fiber
(682d) Low and Reverse Clutch Turbulator Plate - Steel
(683) Thrust Bearing Assembly - Reaction Carrier/Support
(684) Internal Reaction Gear - Model Dependent
(685) Internal Reaction Gear Support - Model Dependent
(686) Reaction Gear/Support Retainer Ring
(687) Output Shaft - Model Dependent
(690) Output Shaft Sleeve - Model Dependent 2WD only
(691) Output Shaft Seal - Model Dependent 2WD only
(692) Reaction Gear Support to Case Bearing
(693) Low and Reverse Clutch Retainer Ring
(694) Low and Reverse Clutch Spring Assembly
(695) Low and Reverse Clutch Piston
(696a) Low and Reverse Clutch Seal - Outer
(696b) Low and Reverse Clutch Seal - Center
(696c) Low and Reverse Clutch Seal - Inner
(697) Oil Deflector - High Output Models Only
(699) Internal Transmission Speed Sensor Rotor
Document ID# 1463397
2005 Che
2005 Che
