Best LT's catted Y combo?
Old 02-18-2006, 03:32 PM
SSmokin99's Avatar
Default Best LT's catted Y combo?
What is the best combo? What exactly will I need after I purchase Lt's and a catted Y?? Will I need o2sims or what? I already have the money, but I need to know what else will be needed. I guess a tune is not needed i heard from my other post
Old 02-18-2006, 04:28 PM
300bhp/ton's Avatar
how much money you want to spend??
Personally I don't think you can beat the Pacesetter and TSP 3" catted Y setup that TSP offer. It's great value for money. You'll also need some o2 sims for the rears and extensions for the front o2 sensors.
But there are lots of options and most LT's can be purchased with a catted variant, although some would require you custom fitting the cats to an ORY. The cats on the TSP setup are also very good ones.
No a tune is not needed, but may be of benefit if you don't plan on any more mods in the near future.
Old 02-18-2006, 06:07 PM
SSmokin99's Avatar
So where can I get that combo? Is TSP a sponsor on Here?
Old 02-18-2006, 09:07 PM
707CamaroZ28's Avatar
Yea TSP is a sponsor
http://www.texas-speed.com/shop/
Old 02-18-2006, 09:16 PM
Louie83's Avatar
I think slpss has the best LT and catted-y combo. I will be going for something pretty similar.
https://ls1tech.com/forums/showthrea...t=QTP+catted+y
Old 02-18-2006, 09:19 PM
Starz T/A 17's Avatar
Another vote for pacesetters and TSP catted Y pipe as soon as I get more $ thats what im gettin
Old 02-18-2006, 09:22 PM
SSmokin99's Avatar
When you order the headers does it come with the left and right side headers?
Old 02-18-2006, 09:24 PM
Louie83's Avatar
Yes, unless you have one of the 4 cylinder vtech SS's.
Old 02-18-2006, 10:55 PM
Redneck Z's Avatar
You probably should be more specific as to what you want, in order to narrow down your search. If money is no object then there is no beating the quality and hp gain of the QTP's & HVMC's. If money is a problem, then the best header for little $$ would have to be the pacesetters hands down.
Old 02-18-2006, 11:49 PM
blkZ28spt's Avatar
READ THE STICKIES.
And search too.
There is no "best combo". It's a matter of personal preferences, tastes, goals, criteria, etc.
Old 02-19-2006, 10:52 AM
WILWAXU's Avatar
Wink
Originally Posted by blkZ28spt
READ THE STICKIES.
And search too.
Why not give him a link to the Sticky?
Mod Guide: Induction and Exhuast
https://ls1tech.com/forums/showthread.php?t=139142
Old 02-19-2006, 02:13 PM
Redneck Z's Avatar
READ THE STICKIES.
And search too.
As far as there being a "best" combo.....I think the QTP's w'HVMC's have proven to be the best when it comes to power gains. As far as quality, they are one of the best in this area also.
Old 02-19-2006, 02:49 PM
99 bad aSS's Avatar
I just got the fully welded edelbrock longtubes w/emissions and ORY. The TI-Tech coating is nice Will be puttin em in on Tuesday. They came with the clamps, hardware and extesions. I just had to buy the sims.
Old 02-19-2006, 05:15 PM
shawn's SS's Avatar
Check out the supermaxx system. All stainless, no o2 sims required (has rear o2 bungs), best ground clearance and all hardware included.
Old 02-19-2006, 05:28 PM
FstBlkz28's Avatar
I am biased, but after having my custom Y on my car ... i'd never go to a prefabbed setup because it'll be hard to beat the fitment to your car. I've got Jet hot LT's, RT 7000 series 3" cats, and a custom 2.5" ypipe. It gives me the best ground clearance of any exhaust system I've had, as well as excellent power.
Old 02-19-2006, 06:02 PM
shawn's SS's Avatar
how much do you have invested in that? Finding a shop willing or competent enough to do a custom Y with out raping most of us is hard to do.
Old 02-19-2006, 08:50 PM
FstBlkz28's Avatar
Well the cats were the most expensive part ... I paid 430 for the 7000 series. The shop that fabbed the Ypipe charged me 375 to:
Cut the collectors back, flange the cats to the collectors
Cut mandrel bent pipe to fit to a flowmaster 2.5"-3" merge collector.
Weld the stock Ypipe brace (pass. side) to the Ypipe so that it could use the stock brace.
AND
Install my hooker catback. So delete whatever the going rate for a catback install and that'd be what they charged me for the Ypipe.
Old 02-19-2006, 09:05 PM
KurtRardin's Avatar
I have the TSP catted y and pacesetters. You'll want to get the 24" extendors too. As far as the sims, well i didnt bother. I just zip tied my downstream o2s to whatever was close by. My Vinci Hiperformance tuner took care of the rest. No check engine lights. Then I used the tuner to advance the timing 10%. That should do until i take it to the dyno.
Very easy install...when compared to installing headers on an LT1 car (nightmare). The only thing I had to do was cut the tab off the drivers side of the block with my sawsall. I could have just opted to jack up the motor though, but i wanted a piece of ls1 in my pocket!
