spare tires as skinnies?
Old 02-24-2006, 08:14 PM
camarofan98's Avatar
Default spare tires as skinnies?
Would it be feasible to run a pair of spare tires (donuts) on the front as skinnies? How come no one talks about doing this, is it unsafe for the track??
Old 02-24-2006, 08:20 PM
EDS01SS's Avatar
no it would not be feasable........and yes it would be very unsafe.the top speed on them dohnuts is 50mph
Old 02-24-2006, 08:57 PM
LS69TA's Avatar
What size is the spare rim? I don't think I've ever looked to see what size the rim is.
Old 02-24-2006, 08:58 PM
EDS01SS's Avatar
i think the spare is a 15
Old 02-24-2006, 08:59 PM
LS69TA's Avatar
135/60/16. Had to go in the garage to see for myself. I guess if you got some different tires it might work...
Old 02-24-2006, 09:40 PM
LS69TA's Avatar
I remember one guy had two of his chrome 16x8 T/A wheels narrowed and was using some kind of motorcycle tire.
Old 02-24-2006, 10:06 PM
2K2WS6TA's Avatar
Using the wheels is a low budget way to get some skinnies, however the tires aren't supposed to be used for anything other than temporary spares (some of the fox body 'stang guys did this in the 80's, but they did replace the tires)
Old 02-25-2006, 03:18 AM
Krab's Avatar
I would assume the donuts are too heavy to have any considerable effect. Have you ever picked one of those suckers? Feels almost the same weight as my stock wheel. The idea behind skinnies up front is to lower unsprung weight and rotating mass along with less rolling resistance. While the skinnier contact patch will decrease the rolling resistance, but the mass is almost the same so it won't change much of the first two. But if you can find them cheap, it's worth a shot. Like these guys already mentioned though, be sure to swap the tires on the donuts because they are rated at less than 60mph.
Old 02-25-2006, 06:37 PM
how do you figure the tire is only rated for 50mph? It says on the rim do not go over 50 when used on the rear, because the smaller diameter tire on one side will mess up the differential. I guess I would have to actually weigh one and weigh a stock rim to see how much lighter the spare is.
Quick Reply: spare tires as skinnies?
