Car not goin into gear???
well about 3 months ago i installed a Textralia clutch. I did not do the drill mod. Anyway i broke in teh clutch and even drag the car a few times before it went away for winter. the clutch seemed fine. Last week it was very nice out so i decide to take the car out. It was real hard to get into gear and would barley go into reverse. I dotn no what to do now is it bc it was cold (i never drove the car with 20-30* temp) or do i need to bleed the system some more, or just do the drill mod? i am lost and i am doin H/C swap hopefully this week so i figured i mine as well fix thsi too
Originally Posted by jermzz
Usually when you can't get it into gear its cause your clutch isn't disengaging all the way. If you changed it, I would follow the above advice and bleed it more.
