Whats the smallest turbo you can run and make power?
Whats the smallest turbo you can run and make power? I found a few that are tiny but was told that it wouldnt do any good in my car. I know I'll need a head change or re-work for a compression drop but the person who told me it wouldnt work didnt know I had raised compression.
I wouldn't go any smaller than a T61...Are you looking at the turbos on ebay?? If so I would not go that route...Get a good turbo man...You'll want something around a T67 or T76 because we're not pushing these with 4 cylinders...smaller the turbo means that you'll max out quicker...
You can go a lot bigger than a t61 sized turbo while retaining your AC. Do you plan on building a custom kit or odering a kit? There are already kits out there that keep the AC.
Check out GMR SPeed-----> single turbo kit. one of the lowest priced turbo kits on the market and comes with all stainless piping and FMIC. Keeps ac and all acc. Shoot for a 61 or better yet a 67mm turbo for your goals.
You could definitely make that power but I would go with a T76 because you're going to want to turn it up eventually...Well when Hi flo releases theirs you could look into that and GMR has a good kit too...PTS, TTI and some other ones have a kit to suit your needs...You may not be able to go to a T76 and retain AC on some of them...You just have to check them out and they'll usually tell you...
