!AIR! Question How to block vacuum line?
Old 03-03-2006, 06:31 PM
ilirw325's Avatar
Default !AIR! Question How to block vacuum line?
How are you guys plugging up the vacuum line when you remove the air system?
Thanks
Old 03-03-2006, 06:39 PM
Doc
Doc's Avatar
Uh, I don't quite follow your question? Do you mean how do you plug the ports on the manifolds or headers?
Old 03-03-2006, 06:50 PM
ilirw325's Avatar
I found JRP post https://ls1tech.com/forums/showpost....0&postcount=20 does everyone use a screw to plug the line off
Old 03-03-2006, 07:54 PM
theinstag8r's Avatar
i have a 98 z28 and all the extra little stuff between the coil packs was connected to the air pump itself on my car. i just removed all the hoses,the air pump,pluged the hole in the intake, and put on race headers and was done with it
Old 03-03-2006, 10:05 PM
Blk02Ls1A4's Avatar
I pulled the line from the back of the intake, removed the "T" and then just connected the line from the HVAC back up. I thought about the screw idea, but this way there is no way anything can go wrong adn cause a leak.
Old 03-03-2006, 10:13 PM
hurley711's Avatar
How many blcokoffs are there for the AIR!? I thought it was just the drivers side header that had a blockoff, is there something in the back of the manifold too?
Old 03-03-2006, 11:01 PM
ls2 bait's Avatar
i just had my manifold off today for the ls6 swap and i didnt see any of that crap??
Old 03-04-2006, 12:57 AM
jrp
SN95 Director
jrp's Avatar
you guys are getting confused, that write up in the guide is for 00-02 cars only, 98-99 have a different AIR system.
Old 03-04-2006, 07:15 AM
hurley711's Avatar
I have an '00 car, guy who did my cam install blocked off drivers side header and I believe nothing else. Is there something in the back that should be blocked off too? My cars idle is dipping to 500 RPMs and I can't figure out why, maybe a leak in the AIR! system is the cause
Old 03-04-2006, 07:18 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
And you won't unless it was provisioned custom. The 2001-2002 did not have the EGR pipe in the manifold.
Old 03-04-2006, 07:42 AM
ls2 bait's Avatar
ummmm ok-- i thought we were talking about thr air system here.......
Old 03-06-2006, 11:37 AM
ilirw325's Avatar
Thanks, thats a good idea
Old 03-06-2006, 12:43 PM
you2slo's Avatar
I used the screw and silicon sealer method. No problems at all.
