problems with right 02sensor
8 SEC SLOPPY SHOT!!!
I just got my car running after sitting all winter just finished up my strange 12 bolt. anyways i a taped my car today and it said bank 2 sencor 1 fault so when i got to work i ordered a sensor and put it in and on the way home same thing. i looked at the harness and everything is fine.and my ltft are way outthere need some help thanks.
Re: problems with right 02sensor
and one more thing my a/f ratio is at 14.6 witch is lean right i'll tune my maft intill my ls1edit comes in. this tuning stuff when your new at it really can **** you off when you don't know what to <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Are BOTH banks LTFTs "way out there" or is it just the side with the bad O2. Can you quantify "way out there". I think that was a term that Maynard G. Krebs used to use, but that was before OBDII. "Way out there" isn't quite specific enough. How about a VDC or a number like -7 or +10. 14.6 is a close to correct stoich as you can be without being spot on.
my ltft's were about +7 range anyways i riched up my car with a maft and it seems to idle better but that doesn't fix my o2 problem on right front it's a new sensor from gm. as soon as it go's into a closed loop i shows faulty that's were my problem is. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
14.7:1 is stoicheometric ratio. Optimum and what is perfect for all driving situations other then at WOT. Being 14.6:1 is right there!
What is the code. There are many O2 sensor codes for our cars, so it could be any of them.
If your using a PCM scanner that complies to EPA/SAE it should have a O2 test. From that you could tell if B2 mirrors B1(s1s) values.
Also via PCM scanner are the fuel trim values of B1 and B2 about the same and same for injector pulse width values ?
Have you reset PCM by leaving power off for some period to see if that would clear the problem up ?
Is B2S1 always reporting the biased 0.450 mVolts or is it switching across 0 volts ?
Use PCM scanner I/M smog tests and see who is getting into a complete state or not.
Not sure where you got the AFR value from but if it was a scanner it most likely was the PCM Commanded AFR value, not the true AFR.
Non smog gas stoch is 14.7:1,
smog gas is 14.2:1 since it contains O2 that will get burned and seen in exhaust.
BTW, I went to Glenbard East H.S in mid 1960s.
I started with Dick Portillo when he frst opened a stand off of North Ave in Glendale hgts, if I had stuck it out I'd be as rich as he got :-)
I do miss that Chi-Town food for sure ..
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by tuff:
<strong> I just got my car running after sitting all winter just finished up my strange 12 bolt. anyways i a taped my car today and it said bank 2 sencor 1 fault so when i got to work i ordered a sensor and put it in and on the way home same thing. i looked at the harness and everything is fine.and my ltft are way outthere need some help thanks. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Well i dissconneted my battery and it seemed fine for a while. what i don't under stand is why when autotap efi live say's there is a trouble code the service light does'nt come on . my fuel trims are right inline from left to right they are at .075 is that good.and the code i get is p0160. will this affect me at the track even when your wot the 02 are open loop. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
whats up with a p0160 code what should i look for i have a new sencor and all the wires look good is there anymore <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
