Stock manifolds upside-down?
Has anyone tried to run any set of LS1-type exhaust manifolds dumping forward and up rather than forward and down? I know lots of people seem to run truck manifolds forward and down for custom turbo setups but I don't ever remember seeing anyboy run truck or any other manifolds dumping forwards and up. What accessory problems would I have if I tried this with some truck manifolds?
Thanks, -Dave
Thanks, -Dave
Originally Posted by coop5885
Wont Fit
Depends what your talking about.
See thread-
https://ls1tech.com/forums/conversions-swaps/449129-turbo-chevelle-gettin-there.html
Hope that helps
ya i tried them in a fbody, definatly wont fit with that but (hits the shock towers) if you can fit them in another model id go for it as it would help with room and accesories.
you might have to mount the coil pack another way, but thats the only thing i can think of.
Thanks A LOT for the feedback and pictures. I was starting to get nervous about my setup. I had the engine and trans in the Jag this weekend and I realized I wouldn't be able to dump my exhaust forward and down due to the Jag crossmember and the engine mount pedestals.
Now I have to make sure that I can get that driver's header around the d@mn corvette alternator bracket!
I was also considering the CTS-V manifolds or the corvette C6 LS2 manifolds but it looks like the truck manifolds should do a fine job.
Originally Posted by blackz93
What is that on the pipe? I see it on several cars, but really never knew what it was?
I'm talking about the piece between the radiator and the motor. About 8" long, or so.
http://www.proturbokits.com/store/sc...p?idproduct=83
see prior posts
