The 383/Phamspeed Build Begins!
Old 03-07-2006, 12:28 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Default The 383/Phamspeed Build Begins!
well we finally started tearing it all down today.Ill be taking pics along the way.So far the front end is off,the headers and true duals are off,the pump is out of the tank to add the second pump in,we mocked up the crossover and dp.and mocked up the turbo and FMIC as well.I KNOW im gonna hear it,but the fitment on the Phamspeed kit was darn near perfect!the crossover is about a 1/4 inch below the bottom of the tranny and everything fit very nice,including the placement of the turbo once we clocked it a bit.And it seems to be high enough that the gravity feed wont be a problem.My only gripe is that the support bar thats supposed to bolt to the side of the block is too short so ill have to lengthen it.I took some pics of all the parts at the shop,on top of which theres about ~20 empty boxes at my house.And i HAD to take a few pics of my babe outside the shop b4 she underwent surgery.Ill update regularly as i get some time.There ya go fellas.
Old 03-07-2006, 06:18 AM
smokinHawk's Avatar
good glad it is fitting well for you. is this the budget kit or tubular kit?
Old 03-07-2006, 07:49 AM
NA$TY-TA's Avatar
Photobucket sucks....... work blocks them.........
Old 03-07-2006, 07:53 AM
chronic masturbator
dynedta's Avatar
kyle & jonathan its the budget kit with shorty headers fwiw
Old 03-07-2006, 09:19 AM
ddnspider's Avatar
Yup its the budget kit with hooker shortys,ill be going back to the shop later so ill have more pics up tonight.
Old 03-08-2006, 07:16 AM
ddnspider's Avatar
Heres the updated pictures.I finished up the triple gauge pod,notice the Eboost which isnt supposed to fit,lol.The front end is off the car and we cut the foam support and the FMIC sits nicely inside there.Were going to try to get it far enough back so we can keep the fog lights but we'll have to see.Also got to work on the dual walbros as well to start the fuel system.I think the car looks mean with the headlights up and no front bumper Enjoy.
Old 03-08-2006, 07:41 AM
CHRISPY's Avatar
Cool!
Old 03-08-2006, 11:01 AM
WestSide's Avatar
Nice progress. I started tearing my car down yesterday to make room for the tubular manifold kit.
Put up a picture when your fmic is on
Old 03-08-2006, 03:11 PM
Got Me SOM's Avatar
i'm heading up to Orlando this weekend to pick up my car, if I have time I'll swing by.
You have enough parts to build a new car from the ground up, lol.
Old 03-08-2006, 03:40 PM
Jax
Jax's Avatar
Good luck with your install. I should be starting on mine very soon...
josh
Old 03-19-2006, 12:00 PM
ddnspider's Avatar
Hey just giving an update.....havent gotten a hell of a lot accomplished as of lately cause of being so busy.As of today all the sensors are swapped over and started putting together the rest of the motor.Have to drill and tap the oil pan today.I cut out the front bumper and tried to create the grill out of a spare license plate frame....unfortunately it doesnt look as good as i would like.....and i got the new knock sensors in since 98's had problems ive been told,and i was also told id need new harnesses which i didnt heres a couple pics
what my babe looks like when empty
hope to get alot more work done this week.
Old 03-19-2006, 12:04 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
What rockers are those?
Old 03-19-2006, 02:25 PM
ddnspider's Avatar
Theyre 1.7 Harland Sharps.i talked w/ Randy Jr about possible problems with the roller tip rubbing the rocker body,he said check after the first 1000 miles and if theyre ok them im good to go.Sorry i dont have much exciting pics or anything yet,its been very uneventful
Old 03-19-2006, 03:48 PM
5.3litre's Avatar
What do you have to drill and tap the oil pan for?
Old 03-19-2006, 03:53 PM
98turbls1's Avatar
For the oil lines for the turbo...
Old 03-19-2006, 06:55 PM
ddnspider's Avatar
you got it,you have to have a feed and a return line for the turbo itself.We got the intake on and TB and setup the rails and 60# injectors,i have to tap 1 of the ends of the rails cause otherwise i wont get even fuel flow But at least my computer got shipped out to Norris on Fri so he can give me a base tune to work with
Old 03-21-2006, 11:55 AM
blacktransam's Avatar
hey because you edited my pic.. i pee'd in your intercooler
Old 03-21-2006, 12:55 PM
ddnspider's Avatar
SWEET!Ethanol!!!!!!what u doing with that pic on Ricks computer,thats just wrong!!!!!!!!lol,rails are tapped and setup up that and injectors,hoping to get the rest of the motor ready today to drop in
Old 03-21-2006, 10:03 PM
ddnspider's Avatar
got some more pics up.i love the way the rails look but i had to tap the end of the 1 rail because they would NOT fit the way they were notched to go,thanks for that SprSpt2000 But the motors coming along nicely....and i hope you guys notice the oil pan picture...thats why i DONT recommend tapping the pan with it still on the car,and there was grease on the tap as well.lol
Old 03-21-2006, 11:02 PM
TeeKay's Avatar
The pics are so big I can't read the text without scrolling right for about a year!
Resize this blog, will ya'? I can't get any intelligence from this post. GL.
Quick Reply: The 383/Phamspeed Build Begins!
