Garage floor paint
Originally Posted by MrBill97396
I forget the nmae of the stuff, but my brother in law has some setup from Lowes that is made for garage floors. All I know ALOT of time involved in it !!!
Was it H& C Concrete stuff?
Originally Posted by Gipraw
I have used U Coat It for my last two floors, and wouldn't even think about using anything else
Originally Posted by shouldaboughttheZ
My father n law bought the stuff from lowes and they even matched the color of the brick from the house. It works great.
Originally Posted by chupr0kabra
I used the Rustoleum kit from Lowes. It was really easy to do and the only problem I've had is that it's peeling where my tires park.
-Mike
-Mike
Originally Posted by 1936FordPU
You put it on thick enough or just use one coat? Did you read the fine print that says it may need touching up once a year? Did you prep the floor with acid etching or did you just wash it like they said to?
The kit I bought came with some citric acid/soap powder that I mixed and used to wash the floor. I followed the instructions to the letter and got very good results.
I'll see if I can dig up some pictures.
-Mike
I used some muratic acid to clean the floor and used epoxy paint. The same stuff used to paint stripes in the parking lots. I added some sand to the paint as to give better wet traction, even with a petroleum based spill. Its just a tad rough on the skin, like when kneeling to run the lugs in with the impact. Just my .02
