how much does it generally cost for gears+install
curious on how much gears+install will usually cost?
if i buy gears myself a shop will install it obviously, do i need anything else to give them??
Hmm...Rear end FAQ at the top of page covers this...
4. What can I expect to pay for a gear upgrade?
A set of gears themselves will cost $150-$250 depending on what brand you purchase. Most shops will charge $250-$400 in labor, and may add more for supplies. Overall, you will spend $400-$700 on a gear change depending on your location. Don’t skip out and go with the cheapest one – be certain that a trained professional is handling your installation!
10. Besides gears, what do I need for an install?
It is good practice to replace all of the bearings when installing new gears…if you have the rear apart anyway; it only takes extra minutes to replace the bearings. A good master installation kit will include everything you need, but specifically if you choose to replace everything you will need: carrier bearings (2), front pinion bearing, rear pinion bearing, crush sleeve, pinion nut, axle bearings (2), axle seals (2), pinion seal, a set of shims, gear paint, loctite, RTV gasket maker, 75w90 (2), GM rear end additive (for LSDs). It is also a good idea to replace the ring gear bolts, which may stretch over time. They are left hand thread, fyi.
crap i feel dumb, blonde moment ha
i usually read the stickys didnt think every area had one heh!
also found out i have 3.23 gears, curious if i need anything else for 4.10s
