3800 Stall daily driver
Old 03-16-2006, 11:20 PM
TA4EVR's Avatar
Default 3800 Stall daily driver
is a 3800 stall converter to much for a daily driver? mostly stock, i drive it alot, its my only transportation for now. Please let me know what you think!
Old 03-16-2006, 11:26 PM
Dmoney's Avatar
I daily drive my 4200. It will feel weird in the beginning, but you get use to it
Old 03-16-2006, 11:27 PM
TA4EVR's Avatar
tranny won't get to hot or anything like that?
Old 03-16-2006, 11:29 PM
Dmoney's Avatar
A nice big tranny cooler solves that.
Old 03-16-2006, 11:31 PM
TA4EVR's Avatar
how much is that? how long can i wait before i need to get one put in?
Old 03-16-2006, 11:37 PM
Jimmy P's Avatar
Install a cooler at the same time you install the converter. Its easy and prety cheap.
I had a 3800 and just upgraded to a 4400. Its not bad at all.
Old 03-16-2006, 11:38 PM
Dmoney's Avatar
I believe I got mine for $50-$60. I suggest to get it put on at the same time. Which converter are you looking to buy?
Old 03-16-2006, 11:48 PM
marooncamaroz28's Avatar
My 3800 is a daily driver. Check with B&M, that's who I used. Pretty easy to install and well worth the money!
Old 03-17-2006, 12:49 AM
BlackHawk T/A's Avatar
You will only spend 50 bucks on a tranny cooler. There is absolutely no reason why anyone should cheap out on it...
Old 03-17-2006, 01:42 AM
DOUBT IT's Avatar
I've been daily driving my TCI4000 for a month now, and I like driving it like this more than I did stock. I also have a B&M 24k cooler hooked up "Dope" style, and the tranny temps haven't gotten over 165 so far, even hot lapping it at the track, and next week I'm throwing on a TCI Deep Pan (2 quarts extra), so I don't see any problem with tranny heat at all.
Old 03-17-2006, 06:16 AM
TA4EVR's Avatar
i found a fuddle 3800 from a member on here, still new in the box. where can i orde a cooler from? can a regular transmission shop install the cooler and the converter? i would do it myself but i'm a traveler and i live in a motel right now so thats not going to work. thanks for your help!
Old 03-17-2006, 06:28 AM
87gnx's Avatar
With a 3800 you should have no problems once you get used to it.It will feel "looser" at first like your not going anywhere from the start.A trans cooler is definitly a good investment(more heat is generated from new 'verter), and another set of rear tires are always a good idea.too.$.02
Old 03-17-2006, 07:55 AM
ls1mongrel's Avatar
Get the tranny cooler , and driving with a big stall just takes some getting used to !
Old 03-17-2006, 08:16 AM
Pontiacerator
RevGTO's Avatar
Note that he has an LT1. 3800 is considered quite high for an LT1 ...
Old 03-17-2006, 09:44 AM
Aha about time someone caught that...
Go with a 3200 for the LT1. Any higher and you will rev past your powerband.
Old 03-17-2006, 02:29 PM
4mula's Avatar
i cooler is a must when doing a t/c
Quick Reply: 3800 Stall daily driver
