Is This Normal
Old 03-17-2006, 08:22 PM
C-17ss's Avatar
Default Is This Normal
I just put in my new spec clutch and every this is fine but it ingages about 1 inch off the floor and before i replaced the clutch it would ingage about 3 or 4 inches off the floor. IS THIS NORMAL. I did not bleed the system because i did not open the hydro system just i just disconnected the slave and reconnected it. Do i need to bleed it or what?
Any info would be great
Old 03-17-2006, 08:31 PM
RoastEmSS's Avatar
I would defenately re bleed it and then see what that does or how you like it
Old 03-17-2006, 09:37 PM
C-17ss's Avatar
I did not bleed it the first time.i was told that if i did not open the bleeder on the clutch that i would not have to bleed it.
Old 03-17-2006, 10:37 PM
Threesixes's Avatar
did you resurface the flywheel and or use one of the shims that came with it?
Old 03-18-2006, 07:11 AM
C-17ss's Avatar
i did resurface the fluwheel and used the shim for the slave
Old 03-18-2006, 09:05 AM
ss1129's Avatar
When I recently changed my clutch to a cheapie luk I had the same thing going on....but it moves to its normal spot after a few hundred miles.
Old 03-18-2006, 10:08 AM
rgaynor85's Avatar
what this guy said the little metal fingers gotto loosen up as u drive and itll go back to normal
Old 03-18-2006, 09:32 PM
00silver6's Avatar
do you have long tube headers?if you do did you check to see how close your hydrolic line is to the header
Old 03-19-2006, 10:06 AM
Threesixes's Avatar
Well I didnt put the shim in after resurfacing the flywheel and the clutch disengaged a lot lower than stock. After a few thousand miles it wouldnt disengage all the way (was hard to get the 2-3 shift at high rpm)and I ended up having to get a McCloud adjustable master to fix it. Thats one way you could go if it doesnt fix itself like the others have said it might.
Quick Reply: Is This Normal
