Turbo Formy Dyno Sheet
stock bottem end with 6l heads and a turbo at 10psi
the black one is the last run we made. it was overlaid with the previous pull. we added some timing earlier in the rpm range. made it look a lot better. 18 total degrees of timing.
hope that pic shows up
Originally Posted by KAOS
i was in town last night i thought about calling you to see if you wanted to race but i did want to be some chode calling you asking if you wanted to race
i want to raise the compression of my stock LS1 enigne. i want to do that by getting custom pistons and leave the heads unmilled. will the LG G5X-4 cam with stock valve be able to clear the custom pistons ( stock LS1 valves)? i want to go to 11.5 :1 compression.
btw, will i have balance problem of the rotating assemblly with only change being the custom pistons?
thanks for the info.
