Northwest Members WA, OR, ID, MT, WY, SD, ND
cam read???
Old 03-21-2006, 12:41 AM
B-RAD2's Avatar
Default cam read???
how do you read a cam and what does it mean can anone explain????
CamIntake Duration Exhaust DurationIntake Lift Exhaust Lift LSA
G2
224
224
.580
.580
114
like that????
thanks guys just trying to learn,
Brad
Old 03-21-2006, 08:26 AM
WAHUSKER's Avatar
Cam 100.5
G2 = the manufactureer's model # for that grind
224/224 = the duration the intake/exhaust valves are open (recall there is 360* in a circle)
.580/.580 = how far the intake/exhaust valves are open at the peak of the lobes
114 = the separation in * between the intake & exhaust valve lobe centers
Now to Cam 101 for what that all means to you.
Everyone has their own opinions about what cam profile works best on an LS1 motor. And it really depends on your other mods, and what you plan to do with the car. The 224 cams are a good all-around cam. Good mid range power, and a bit of a lope at idle. You can get more power with another cam (like say at higher rpms for road racing) by playing with durations & separation.
I think LS1s like a little more exh duration, but that's my opinion. I also like a little less separation because I like a nasty idle. But those are harder to tune (especially with an auto) and do NOT play well with boost. And once you get near .600 lift, clearance with the pistions becomes an issue. As does your valve springs. The bigger your cam is, the better springs etc you need to make it work (or your valves float at hi rpms).
There is also the ramp rate to consider that many places don't talk much about. The faster you open that valve, the more air you can move. But it is also harder on the springs & lifters.
There is more to a cam selection than this. It's all about matching it up to YOUR car. If you want the best cam for your application, I'd call Ellis. Between him & Jimbob, they will pick out a grind that will make you & your car happy.
Old 03-21-2006, 10:46 AM
B-RAD2's Avatar
hey thanks mark
Old 03-21-2006, 10:56 AM
B-RAD2's Avatar
what is a good cam to go with if i want a decent lobe that can be heard and good power. something along the lines of and z06 cam but alittle more aggresive.
Old 03-21-2006, 10:57 AM
NWDragRacer's Avatar
Originally Posted by WAHUSKER
Cam 100.5
And for Mark, there's...
Engine 70 - Remedial Four Stroke Engines or "Four Strokes for Dummies"
The 224/224 refers to the number of degrees that the valves are open during one firing cycle of a 4 stroke engine. Since the engine rotates twice for every firing cycle, there are 720* of crankshaft rotation - of which the valves are open for 224*.
Old 03-21-2006, 11:15 AM
B-RAD2's Avatar
how about a 224/224 .563/.563 112 LSA
would i need to change my springs
Old 03-21-2006, 12:45 PM
Tech Addict
Rokko's Avatar
If you have stock springs, I would change them with a cam swap.
Old 03-21-2006, 12:50 PM
WAHUSKER's Avatar
True, but the camshaft rotates at 1/2 the speed of the crank, so it's 360* for it. But what you're saying is the valves are actually open for 112* of the cam rotation. Which makes sense as I think about the lobes....never thought it out that far.
Old 03-21-2006, 12:55 PM
Tranzor's Avatar
Any cam swap you make, you will have to change the springs (if they're still stock). Unless of course you get a killer aftermarket cam with less than .500 lift and 200/200 @ .050 and ultra-slow ramp rates.
Old 03-21-2006, 12:57 PM
Tech Addict
Rokko's Avatar
and just to clarify......
The 224* duration number is measured at .050" lift.
If I have this correct, and I'm not sure I do right now. The valve would be open for 224* of the 720* of crank rotation and open for 112* of the 360* of camshaft rotation, after the lifter has moved up off the base circle .050"
Is that right?
Old 03-21-2006, 01:01 PM
Tech Addict
Rokko's Avatar
Good point, now I need to edit my post.
Old 03-21-2006, 01:05 PM
Tech Addict
Rokko's Avatar
Originally Posted by Tranzor_Z28
Any cam swap you make, you will have to change the springs (if they're still stock). Unless of course you get a killer aftermarket cam with less than .500 lift @ .050 and ultra-slow ramp rates.
less than .500 @ .050?
Old 03-21-2006, 01:15 PM
Tranzor's Avatar
Sorry, just forgot the duration in my haste to post... look at the edit, better?
Old 03-21-2006, 01:35 PM
Tech Addict
Rokko's Avatar
500 @ .050 would be a bit big, dontcha think.
Old 03-21-2006, 02:11 PM
Tranzor's Avatar
Not if your name is Sardog.
Old 03-21-2006, 02:25 PM
Tech Addict
Rokko's Avatar
I miss having that sumbish around.
Quick Reply: cam read???
