belt change, what will i need?
Old 03-21-2006, 08:29 AM
bigti99a's Avatar
Default belt change, what will i need?
i noticed my serpentine belt showing some wear. when replacing it what else in the pully system should be changed? any pullies, tensioner, anything like that? also is there a belt that is better than another? any help would be great i am trying to knock this job out soon. any other tune up like things i should be doing on a 77k z-28 feel free to make sugestions. i have fresh plugs, wires, coolant, trans fluid.
Old 03-21-2006, 09:18 AM
GreekGator's Avatar
fuel filter and rearend fluid...
Old 03-21-2006, 09:22 AM
waiting2bl33d's Avatar
alright the first question. if you have noise find out what pulley it is comming from then replace if quite then all you will need is a belt. next answer. you didn't mention changing your rear diff. fluid. other than that just take a gander in your manual it tells you what to replacing.
Old 03-21-2006, 09:41 AM
bigti99a's Avatar
i have a new fuel filter as well. rear end service is definately on the list as well.
i dont really have noise coming from the belt. its just showing some wear, small cracks and what not. thanks, any other suggestions or experiences welcomed!
Old 03-21-2006, 03:37 PM
bigti99a's Avatar
i am trying to order a belt. should i get the original gm one, whatever auto zone has, or i have heard of people talking about a gatorback belt. any input?
Old 03-21-2006, 03:48 PM
rtr2001ss's Avatar
All you'll need, 15mm socket/wrench and new belt. Check AC belt too while your there. If you need to replace that, you'll need the serpintine off first. The belt from Advanced or Auto Zone will be fine.
Old 03-21-2006, 08:24 PM
savethelinoleum's Avatar
Yea replacing your serp belt is really easy, you just turn the 15mm nut that is on the tensioner pulley clockwise (as though to tighten) and it will move down and you'll be able to work the belt off. Don't pull it down too far clockwise though because it's just a spring inside that tensioner pulley and you can dislodge it.. then you have to take off the pulley, the cover and put the spring back in place. Just a word of caution. I bought the gatorback belt because it was only like $20 versus $13, it was pretty noisy for the first few blocks, it's gotten quiter, I don't think there's really that much of a noise difference overall.
Old 03-21-2006, 10:01 PM
bigti99a's Avatar
any idea what the part number was for that gatorback belt savethelinoleum?
Old 04-01-2006, 02:58 AM
Shallow Bay's Avatar
GATORBACK POLY-V Part No. 4060790
GATORBACK POLY-V W A/C Part No. 4040410
