wiring diagram
Closed ex-Sponsor Account
Originally Posted by smokeum99ta
I need a wiring diagram for a MSD (non digital) windows switch. I'll be using WOT switch. I have the NOS 5177 kit.
Hope this helps.
Ricky
Originally Posted by NXRICKY
Dan, the FJO controller comes with a diagram. Not sure which one you are looking for?
I will be more than glad to help, but need a little more info.
Ricky
Ricky
Do I just wire the ground wire from the relay to a contact on the pressure switch and then wire the other contact to a ground on the chassis?
Thanks!
-Dan
Originally Posted by cleveland
alright, how does a fuel pressure safety switch get wired into the wiring diagram for the 2-Stage Progressive Mini-Controller (diagram 11)?
Thanks!
-Dan
Thanks!
-Dan
Ricky
alright, now only if I can figure out which numbered prong goes where.
edit: #30 to +12v
#86 from activation circuit
#85 to -12v (fuel pressure safety switch then grounded)
#87 to solenoids
Is this correct?
-Dan
edit: #30 to +12v
#87 to solenoids
Is this correct?
-Dan
