Tach wire for MSD Window Switch?
Restricted User
I thought this would be a simple question but I still can't figure it out. I have read that it was Pin #10 but when i pull out my PCM what do you know I have NO Pin #10 Wire. Somebody Please Help!
Its a white wire(#10) that comes out from the PCM, you do not have to pull the PCM to get to it. If you look at the PCM while its installed where the wires all come out you can read the wire numbers.
IT IS PIN 35 ON 98 CARS AND IT IS PIN 10 ON 99 AND UP HERE IS A CHART TO CHECK OUT.www.ls2.com/boggs/torques/enginetorques.htm IT HAS EVER THING YOU NEED. THEN GO TO 98 PCM PIN ASSIGNMENTS.
Is there a site with some photos showing pin 35 (98 C5 LS1). I've got my battery tray out now and can see lots of 'dirty' black wires, but no blue/red circuits. Do I need to pull out the computer from down below the battery?
