200r4
Old 04-16-2006, 02:49 AM
JerikSS's Avatar
Default 200r4
Im trying to get one of these on my 2001 ls1 M6. How do they work as apposed to the 4l60e, do I have to manually shift the transmission like im driving stick or does it do it for you like the electric???? I have always wonder? How high does it typically rev???? at about 80mph
Old 04-16-2006, 10:14 AM
chris718's Avatar
the gear ratio is more favorable than the 4l60e and the overdrive allows less rpm at a given road speed verses the 4l60e.check out the post on my 200 page manual.itll go right yur car and will auto shift.you need to install a tv cable between the throttle and trans to give the trans a throttle position signal as an input to control shift scheduling.
Old 04-16-2006, 01:13 PM
Moderator
jimmyblue's Avatar
Be sure you get one with a bolt pattern that will
work, some cases had a universal and some were
BOP-only (Buick, Olds, Pontiac). This trans has
had a lot more years in the aftermarket and the
GN performance segment in particular drove some
pretty decent beef-up. A really popular trans for
retrofit to older TH350 vehicles, minimum "stuff"
involved and no pesky electronics.
Old 04-17-2006, 01:06 AM
JerikSS's Avatar
so it will be a full automatic, I will be able to drive with my legs and my hands holding a cell and a drink???????????????????????
Old 04-17-2006, 05:39 AM
sroka's Avatar
They are automactic shift, so just put it in overdrive and and go.
Old 04-17-2006, 10:09 AM
Yank's Avatar
Here is some info we did on the swap m6-a4
http://www.ls1camaro.net/article.php?sid=33
Old 04-18-2006, 04:03 PM
JerikSS's Avatar
How much will it cost me to install??
Old 04-30-2006, 11:35 AM
bluecamaroz28's Avatar
Both have OD and very close when it comes to gear ratio. The 4L60E has a lower 1st gear and 2nd gear.
Stock to stock not sure if anyone is stronger. I would say get the 4L60E and tune the PCM for it.
200- 4R 2.74 1.57 1 0.67
4L60E 3.06 1.63 1 0.7
