"D" or "OD"?
Old 04-17-2006, 11:03 AM
TXZ28LS1's Avatar
Default " D" or "OD"
hey guys, is it better for an auto to be in OD or D? which is better for daily driving and which is better for racing. i always thought just leave it in regular "D"!!
Old 04-17-2006, 11:07 AM
SSU'S Vice Mod
sb427f-car's Avatar
OD is usually where the tq converter will lockup for extended cruising. If you're racing, it's unlikely to lock up anyways as it'll be under load, but it wouldn't hurt to leave it down into D to play it safe. Also towing I would not use OD. What trans, 4l60E?
Old 04-17-2006, 11:28 AM
AronZ28's Avatar
I leave it in OD for my Z28 all the time, unless I'm going crazy around a backroad or at the strip where it doesn't need to shift into OD.
In some of the other POS cars I've driven I'll leave it in D going around town because it'll shift into OD, then back into D when you get on the gas because it doesn't have any power. Keeps the tranny from going beserk and shifting all the time.
Old 04-17-2006, 11:29 AM
camaroextra's Avatar
yeah for drag racing OD shouldnt be a problem.
Old 04-17-2006, 11:34 AM
ls1mongrel's Avatar
I leave mine in od all the time, I just have my lock up set for 50mph, so it never locks up in town !
Old 04-17-2006, 11:37 AM
Lordsauran's Avatar
Mine doesnt say "OD", mine only has 1,2,3 and D so it stays in D all the time lol
Old 04-17-2006, 11:41 AM
its the d surrounded by an ovalish thing
Old 04-17-2006, 11:44 AM
LS1Tech Co-Founder
Nine Ball's Avatar
no difference. It won't go into OD at wide open throttle anyways.
Old 04-17-2006, 11:51 AM
formula001's Avatar
In pontiacs the "3" is Drive and "D" is OD.
Old 04-17-2006, 12:05 PM
ohhh just kidding then
Old 04-17-2006, 04:29 PM
Board Certified Idiot
Z2K_MrJ's Avatar
Dont Leave it IN OD When Racing From Low Speeds, It will Wear out your Tranny Much Faster. Then Leaving it in D
Old 04-17-2006, 04:39 PM
Roarin_8's Avatar
The only time I leave it in OD is when crusing on the highway, everywhere else I leave it in D. For a stock stall, leaving it in OD is fine.
Old 04-17-2006, 04:48 PM
burnzilla's Avatar
If you speed shift a 4L60E, you are a fucktard.
Put it in D, then roll the notes.
Old 04-17-2006, 06:13 PM
SmokingWS6's Avatar
Except when I'm going over 135
Old 04-17-2006, 07:08 PM
CrabhartLS1's Avatar
OD= daily driving, it's the most conservative setting the tranny has, for people who leave it there.
D= quicker shifts, stays in gear longer, drops down in less time, basically the performance aspect.
the 4l60e is a 3 gear transmission with an extra gear for cruising.
Old 04-17-2006, 07:22 PM
WILWAXU's Avatar
Leave it in D unless you have problems hitting the limiter. Then try OD. If that doesn't work, it's probably time for a rebuild
Not true (on the car 4L60's at least).
Old 04-17-2006, 09:31 PM
glitch77's Avatar
I SWEAR I've hit 4th gear at WOT in my car. About 145-ish or so?
Old 04-17-2006, 09:37 PM
j3ff's Avatar
People with automatics.........so sad
Old 04-17-2006, 09:42 PM
formula001's Avatar
Old 04-17-2006, 09:51 PM
Luna's Avatar
So in a Pontiac 3 is D and D is OD ?? it seems like it would be the other way around but if you say so...
