6.0 Heads Vs 5.3 Heads
Re: 6.0 Heads Vs 5.3 Heads
you can use a bigger cam with the 5.3's and not have to worry about P/V clearance like you do if you mill a lot off of the 6.0's.
It's easy to get 11:1 compression from the 5.3's with slight milling, where the 6.0's would take quite a bit. 6.0's would be better for FI applications or strokers.
Correct me if I am wrong guys... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
5.3 heads will rtequire chamber work to flow any where near 5.7 or 6.0. Chamber work if done by hand is critical because different size chambers will cause missfires and incorrect o2 readings. Fully ported 6.0 will not flow 30 to 40 more cfm than ported 5.3 heads either. Just trying to be helpful.
Just fine, 6.0 will probably flow 10 cfm more but will have less compression, so power will be similar with same effort into both castings.
LS1TECH Sponsor
Be careful as to how large of valves you try and put in the 5.3 heads. I recently was witness to some 2.02 valves that were machined into a stock seat and the seats are actually cracked and began breaking apart in the head. This was also the case on the exhaust valve, but I cant remember the size. The seats need to be changed if larger diameter valves are to be installed in the 5.3 heads. Ask whoever you buy your heads from about this, if they dont know or dodge the question, CAREFUL!!!
Yeah 2.02 valves need a new seat in the 5.3L heads.
LS1derfull I have only seen 300cfm numbers out of 5.3L heads and 340cfm numbers out of 6.0L heads. So if you have seen 5.3L heads that flow more tell me about them, because I might want a set.
If you have the extra cash for the 6.0L cores then get those puppies milled down and have them ported. That's a more expensive way to go but it will work.
Bret
Bret
