Drag Racing Tech
Question about tire diameter?
Old 04-21-2006, 06:13 AM
LSs1Power's Avatar
Default Question about tire diameter?
Im running 315/35/17 tires now which should be around 25 or 26" right? Im running out of 4th gear in the traps.
My question is how much would a 28" tire help in this situation? How much faster can you go in 4th gear with a 28" tire compared to 25-26" at the end of the traps?
Thanks
Old 04-21-2006, 09:41 AM
RaNsOm's Avatar
your tire is about a 26". what size gears do you have?
I use 4.33's and a rev limiter of 6700 and I have stuff enough RPM left using 27" tires.
Old 04-21-2006, 11:26 AM
Anidote00's Avatar
A 28" would help out alot!! You could probably run at least another 8-10 mph if not more, with a 28" tire.
Old 04-21-2006, 12:17 PM
T6Rocket's Avatar
It is 25.6", pretty small. 28" tires would be a big difference!
Al
Old 04-21-2006, 02:44 PM
LSs1Power's Avatar
So a 28" tire should be good for around 136mph in traps with a 3.73 gear? My 25.6 tires got close to 6700RPM with a slipping clutch trapping 127mph. Thats when i had 548rwhp on the dynojet. Now i have 130-160rwhp more that before with a new clutch. If the 28" tire can give me up to 136mph that would be great.
Isnt there a way to calculate the speed possible with tire size and gearing?
Old 04-21-2006, 04:34 PM
RaNsOm's Avatar
www.f-body.org/gears
Old 04-21-2006, 05:11 PM
LSs1Power's Avatar
Originally Posted by RaNsOm
Thanks for the link
I did the numbers there and it showed 13 mph more at 6700RPM running 28" tires instead of 25.6"
Im not really sure about the calculator though because it showed the 25.6 tire good for 137mph while i was close to my limiter which is around 7K RPM (I remember getting shift light on before i passed the traps and my shift light is set at 6300RPM) and only trapped 127mph.
I used these gearings numbers for the T-56, 2.66, 1.78, 1.3, 1.00, 0.74, 0.50
Old 04-21-2006, 05:15 PM
blkchevyz's Avatar
hoosier quick time pros are 26.3 or 26.4
depending on how much more you need.. those could help.
