Can I spray to 565 on a stock bottom?
Last night I had a dyno session at HiTech Motorsport. They installed their new Predator H/C/FAST high velocity combo on my car. (228/232 585/585 114/velocity ported 5.3 heads/ velocity ported 90 mm FAST intake manifold) We are very pleased with the results considering my bottom end is stock
Here are the last three pulls (SAE corrected):
461.28/426.21
462.78/428.95
460.49/430.81
Here are the last three pulls (STD corrected):
471.98/436.09
473.33/438.73
471.15/440.78
Can I spray a 100 shot or a 150 shot with this much power on a stock bottom? Can I even spray a 75 shot? I do have a Racetronix Fuel Pump Kit going in, but I don’t know how much power I can put through a stock internal LS1???
What are your thoughts?
461.28/426.21
462.78/428.95
460.49/430.81
471.98/436.09
473.33/438.73
471.15/440.78
Originally Posted by cws T/A
thats some of the better numbers ive seen H/C/I do you have a graph
550-650 spray it
550-650 spray it
Thanks for the input so far. Any more input from people spraying that much HP through a stock bottom would help.
I have seen 680 rwhp on stock bottom end. I have also seen a piston pop at 500...but very rare. 580 should be fine with tuning...especially since the majority of you power is coming NA. I would retard some timing...just a little...or use 100 octane.
I say that because I am assuming your timing is pretty agressive on your NA tune.
Hey whats up jeremy!!
last year i was spraying 150 on stock internals at 572sae. Now this year if brain ever gets back to get my car tuned I'll be at least 580-600. So I guess i'll be hoping to keep it together too.
sorry to intrude but i have 450 hp off a procharger i just got done with my fuel system inline booster pump in the process of gettin nasty rails, i have a fpr and all -8an fuel lines, how much could my motor hold safely this is my dd. ?
Originally Posted by GDM Z28
we took joes (1999redws6 or something like that) ta to the dyno....428 on motor and 667 on nitrous. Stock bottom end.
Originally Posted by HAULNTA
Is this car still running?
Tuned by jeremy and trust me it wasnt a stock fuel system on the car.
461.28/426.21
462.78/428.95
460.49/430.81
471.98/436.09
473.33/438.73
471.15/440.78
461.28/426.21
462.78/428.95
460.49/430.81
471.98/436.09
473.33/438.73
471.15/440.78
