Can I spray to 565 on a stock bottom?
Old Apr 22, 2006 | 10:54 AM
HAULNTA's Avatar
Default Can I spray to 565 on a stock bottom?
Last night I had a dyno session at HiTech Motorsport. They installed their new Predator H/C/FAST high velocity combo on my car. (228/232 585/585 114/velocity ported 5.3 heads/ velocity ported 90 mm FAST intake manifold) We are very pleased with the results considering my bottom end is stock
Here are the last three pulls (SAE corrected):
461.28/426.21
462.78/428.95
460.49/430.81
Here are the last three pulls (STD corrected):
471.98/436.09
473.33/438.73
471.15/440.78
Can I spray a 100 shot or a 150 shot with this much power on a stock bottom? Can I even spray a 75 shot? I do have a Racetronix Fuel Pump Kit going in, but I don’t know how much power I can put through a stock internal LS1???
What are your thoughts?
Old Apr 22, 2006 | 11:03 AM
BAKED's Avatar
Hell yea, people do it every day.
Old Apr 22, 2006 | 11:05 AM
cws T/A's Avatar
thats some of the better numbers ive seen H/C/I do you have a graph
550-650 spray it
Old Apr 22, 2006 | 11:18 AM
HAULNTA's Avatar
550-650 spray it
I have a bunch of graphs but I don't know how to post them. I can email them to you.
Old Apr 22, 2006 | 11:44 AM
WOT's Avatar
WOT
without a doubt. just take your time tuning.
Old Apr 22, 2006 | 12:04 PM
HAULNTA's Avatar
Thanks for the input so far. Any more input from people spraying that much HP through a stock bottom would help.
Old Apr 22, 2006 | 12:13 PM
jwitt2's Avatar
pm the guy "blacktransam' on this board, he sprays a 200 shot on his stock bottom end for like 580/617.
Old Apr 22, 2006 | 02:01 PM
383LQ4SS's Avatar
I have seen 680 rwhp on stock bottom end. I have also seen a piston pop at 500...but very rare. 580 should be fine with tuning...especially since the majority of you power is coming NA. I would retard some timing...just a little...or use 100 octane.
I say that because I am assuming your timing is pretty agressive on your NA tune.
Old Apr 22, 2006 | 08:52 PM
brad8266's Avatar
those are awesome numbers for that combo, I would spray it, it will hold a 100 shot im sure, just be sure to have the fueling to support it and retard timing a little.
Old Apr 23, 2006 | 10:33 AM
beardWS6's Avatar
I sprayed a 150 shot on my H/C set-up. Just tune it right and run alittle rich. Pull alittle timing and you will be fine. Just don`t run out of fuel up top. DON`T RUN LEAN!!!
Old Apr 23, 2006 | 06:18 PM
1MEANGTO's Avatar
Hey whats up jeremy!!
last year i was spraying 150 on stock internals at 572sae. Now this year if brain ever gets back to get my car tuned I'll be at least 580-600. So I guess i'll be hoping to keep it together too.
Old Apr 23, 2006 | 10:42 PM
HAULNTA's Avatar
I guess we will see soon. I,m going to try a pulley and shoot the 75, then the 100.
Old Apr 23, 2006 | 10:58 PM
rmitchell242's Avatar
I have 493 n/arwp on a stock ls2 and i am setting up a dual dry shot that will be around 175 all together so i should be well over 600, so I say go for it
good luck!
Old Apr 23, 2006 | 11:30 PM
ws6charged's Avatar
sorry to intrude but i have 450 hp off a procharger i just got done with my fuel system inline booster pump in the process of gettin nasty rails, i have a fpr and all -8an fuel lines, how much could my motor hold safely this is my dd. ?
Old Apr 23, 2006 | 11:59 PM
GDM Z28's Avatar
we took joes (1999redws6 or something like that) ta to the dyno....428 on motor and 667 on nitrous. Stock bottom end.
Old Apr 24, 2006 | 10:45 AM
HAULNTA's Avatar
Is this car still running?
Old Apr 24, 2006 | 10:58 AM
GDM Z28's Avatar
yeah....the car was sprayed on the dyno, at the track a bunch of times, and on the street....
Tuned by jeremy and trust me it wasnt a stock fuel system on the car.
Old Apr 24, 2006 | 07:53 PM
SmaknaSS's Avatar
Damb! what HP shot was he using?
Old Apr 24, 2006 | 09:00 PM
1BDHWK's Avatar
461.28/426.21
462.78/428.95
460.49/430.81
471.98/436.09
473.33/438.73
471.15/440.78
Should be no problem with a good tune. Make sure you get a window switch! I found out the carnage of tapping the rev limiter with the shot. Blew the back of my FAST 90 out(An open hand size hole )It's not nice! I have a rev limiter now. But spray and enjoy!
Old Apr 24, 2006 | 10:08 PM
CAT3's Avatar
Restricted User
There goes Ben blowing **** up again! Damn, you fisted your LSX intake....gees.
Making that kind of NA power is pretty damn good for stock bottoms. Tune it and spray it.
