MTI G1 vs. X1
MTI G1 vs. X1
which of these 2 would be better for a DD auto? car will never see the track. i plan on going with 3200 stall and some 3.42 or 3.73..kinda leaning towards the 3.73.. i guess i want a nice all around performing setup without over caming my car..lol.. i want something that still has good tq down low and can pull from a roll...
14 Second Truck Club
If you get the G1 you will just want to go bigger later on, i already want a bigger one haha....might as well get the x1 the 112 LSA will lobe very nice
yeah i hear that x1 sounds bad a$$ at idle.. do you think that 3200 stall will work good with it.. and is 3.42 better than the 3.73.. i talked to david at mti he said run that x1 with a 3200 since its a daily driver. i just wanted to get more input.. thanks guys..
my budy jay and a few others told me to get the 3:42 since i have an auto if that helps
well when i MTI i had put a G-1, yank 3200, 3.73 & other bolt ons. i put down 360 hp & 363 trq. the car is a good dd, but with the 3.73's it wasted a little more gas. also there were times that you would turn it on and it would turn off cause of the idle. this was back last summer and i am thinking about going bigger.
Both cams are great. If you are a nitrous junky might want to lean towards the X-1,
the G-1 has killer mid range torque. both make same horse power up top. my 2 cents...
yeah man i know they should be close as far as hp. .i know the x1 will probably pull harder up top while the g1 has more torqe. i guess if i were to do a head and cam with either of these cams, which would be better for a street car and pull on pullied cobras!!
