electric cutout placement??
Old 04-25-2006, 11:08 AM
slt200mph's Avatar
Default electric cutout placement??
Where to place the cutout or cutouts if runing true duals or y pipe w\o cats with cat back system..would one on each side of the y pipe be too close to the o2 sensors??
Old 04-25-2006, 01:50 PM
GuitsBoy's Avatar
Id put them after the Y for the o2's sake, as well as the cooler exhaust extending the life of the e-cutout. If possible, Id put it behind the rear axle - It will still be pretty loud, but if it leaks, it wont bother you as much. Running cutouts on dumped duals is pretty pointless since they wont flow any better. If you run duals over the axles, Id follow suit with teh Y pipe setup. My cutouts are going behind the axle, but before the mufflers on my OTA duals.
Old 04-25-2006, 01:52 PM
ws6togo's Avatar
I ran mine in the I-pipe. Right by the rear passenger seat. There is even a rubber grommet to allow for wires if you run the electric cutout
Old 04-25-2006, 06:35 PM
bad6as's Avatar
i dont think ill gain even 3 hp/tq with a cut out with lt, ory, lmII or would i?
Old 04-25-2006, 11:05 PM
ws6togo's Avatar
with your LT's I wouldnt waste my time with cutout. go duals and dump it
Old 04-25-2006, 11:45 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Nothing but good thinking here.
Old 04-25-2006, 11:54 PM
Starz T/A 17's Avatar
If usings a Y pipe setup I would put it at the end of the Y pipe but if running TD's I wouldnt even bother with cutouts
Old 04-26-2006, 07:23 AM
slow trap's Avatar
my cutout is at the end of the i pipe also.even open it is not overly annoying.
Old 04-26-2006, 07:57 AM
slt200mph's Avatar
TD dumped...Been there done that way too loud.. ..can't hear the stereo or have a conversation without yelling.....TD's need to go out the back..
Old 04-26-2006, 08:33 AM
2mffZ28's Avatar
Agreed
I have mine at the end of the I pipe pointing out the rear of the car. allot less drone than mid I pipe.........been there too
Old 04-27-2006, 11:07 AM
ws6togo's Avatar
My cutout being by the back seat idled louder than my duals. When I first drove my duals i thought "now it sounds like p#$y car" I am using reverse flow glasspacks <sp>. My dual setup doesnt get loud till i get heavy with my foot. But at least now I can hear the cam
