Drag Racing Tech
Hawker Battery
Old 04-25-2006, 11:57 AM
Racer8102's Avatar
Default Hawker Battery
I just got done installing the PC680, but I have a question, when the car is running the volt guage jumps around (I have a 98 model so the guage works) and I can see the lights get dimmer and then brighten up. I checked all my connections, everything is tight, any ideas on what the problem is?
Old 04-25-2006, 12:47 PM
Blown408's Avatar
Sounds more like an alternator problem like I had once. I had a small independent shop rebuild mine years ago, and they put the wrong parts in. At idle, my gauge and lights would do as you describe. When I would bring the rpms up, the gauge would stay at 13. Just a thought.
Old 04-25-2006, 01:35 PM
Racer8102's Avatar
I thought about that but the only thing is everything was fine till immediately after I hooked this battery up, I am wondering if the surface area of the connections on the new battery is not enough (only about the size of a dime) and uses 6mm screws to hold the wires on. I was hoping someone using one of these batteries would chime in and give a little more info. I may go ahead and buy the terminals that screw into the battery and give it a little better fit.
Old 04-25-2006, 05:10 PM
FloydSummerOf68's Avatar
Mine does the same thing, and the alternator is fine.
Old 04-25-2006, 06:02 PM
Blown408's Avatar
I forgot about that. I had to use a couple of washers under the cable to get the cable to tighten down good against the battery.
Old 04-25-2006, 06:33 PM
Restricted User
CAT3's Avatar
I have that battery and no issues like that and I do not use washers on the terminal. I do however want to order a set of the adapters that screw into the 6mm hole and uses a "stock" type bolt into that.
Old 04-25-2006, 06:41 PM
SPEEDYws6's Avatar
I had that issue a few months ago. I put a new altenator on it and it fixed it. It did this with a delco battery and an optima yellow top.
Old 04-27-2006, 08:38 PM
SUX2BU's Avatar
My car did this and its a 98. i swapped out alt's and it stopped. i daily drive my pc680.
I wouldn't worry about it unless it really bothers you.
Old 04-27-2006, 11:26 PM
Racer8102's Avatar
Thanks for the responses, I will prolly leave it like it is, it doesn't seem to do it when the rpm's are up, might check into getting a new alt. later on.
Old 04-27-2006, 11:28 PM
SUX2BU's Avatar
I would just swap out with a buddy before spending any coin. Don't take but 20 min.
Old 09-10-2007, 10:22 AM
NickcZ28's Avatar
Hey Juan Where did you get your hawker in the DFW area I know somewhere has one!
Old 09-10-2007, 10:52 AM
daniel6718's Avatar
well thats old...get it off the web for 75 shipped to your house....idk if anyone local has any...prolly be more expensive though
Old 09-10-2007, 01:57 PM
Bitemark46's Avatar
I know ebay has them. Price is comparable to other internet sites. -Mark
