TB question(easy one)
Old 05-01-2006, 08:35 AM
bigti99a's Avatar
Question TB question(easy one)
i picked up a throttle body that was on a 2001ss. before i make a mistake and send it out for porting i want to be 100% certain there will be no problems just switching the sensors over from my stocker and putting it on with a new gasket. i have an 00.
Old 05-01-2006, 08:59 AM
brad8266's Avatar
Shouldnt be any problems.
Old 05-01-2006, 09:06 AM
FstBlkz28's Avatar
Notta problem at all.
Old 05-01-2006, 11:10 AM
daryl2cb@yahoo.com's Avatar
same thing, no issues
Old 05-01-2006, 12:52 PM
bigti99a's Avatar
thanks guys.
Old 05-01-2006, 12:56 PM
That's what she said...
TheBlurLS1's Avatar
You don't even need a new gasket.
Make sure you get the IAC plunger's o-ring when you pull it out (top of throttle body, driverside) and install it in the new one. My car had a bit of idle surging when I swapped to a ported one, traced it back to that o-ring being MIA.
Old 05-01-2006, 06:48 PM
bigti99a's Avatar
Default follow up question
are there and if so what are the torque specs for the TB. and is there any trick i should know to get the old one off and new one on? thanks again for any help.
Old 05-01-2006, 08:59 PM
bigti99a's Avatar
ttt, looking for a little input, thanks.
Old 05-01-2006, 09:09 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Make sure that the throttle blade assembly will work if you have an early model.
Old 05-01-2006, 09:13 PM
STRETCH'S T/A's Avatar
when taking old one off you have to remove everything up to the tb, then unplug the sensors, and hoses to get at the 3 bolts to get it off. when intsalling the new tb, just tighten the bolts til they no longer turn, don't overtighten them or you could damage the intake.
Old 05-01-2006, 09:31 PM
bigti99a's Avatar
thanks stretch
Old 05-01-2006, 11:43 PM
Luna's Avatar
Originally Posted by everclear4520
post junky
You're cruising for a banning
Old 05-01-2006, 11:44 PM
Drew's TA's Avatar
No kidding, every post he has made has been "post junky".....
Old 05-02-2006, 12:49 AM
TheBlurLS1's Avatar
He's on trail in the admin lounge as we speak.
Old 05-02-2006, 12:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I was sick of it...
Old 05-02-2006, 07:27 AM
bigti99a's Avatar
did i miss something?????
Old 05-02-2006, 07:48 AM
GuitsBoy's Avatar
Like orange said, make sure the TB shaft cam is the same size. The 98-99, and possibly early 00's had a smaller cam so youll have too much throttle cable.
Old 05-02-2006, 07:51 AM
bigti99a's Avatar
is it obvious enough to see with the eye?
Old 05-02-2006, 07:55 AM
GuitsBoy's Avatar
Yes, should be immediately noticeable side by side.
Old 05-02-2006, 08:18 AM
bigti99a's Avatar
pardon my ignorance but the shaft cam is the little half moon on the side of the TB right?
