SES...o2 low volts???
Old 05-01-2006, 12:12 PM
DomesticLS1's Avatar
Red face SES...o2 low volts???
Hi just the other day I punched my 99 t/a and my ses light came on. I immediately took it autozone and they said that both bank 1 sensor 2 and bank to sensor 2 had low volts. I then bought 2 new bosch sensors and then when I punched it again my light came on. If I drive around for awhile my light will usually go back off. But once it came back on I took it back to autozone to see what it could be now. They said it was the same sensors with low voltage...so hmmm???? There new sensors still with low voltage...Does anyone know what this could be???
Old 05-01-2006, 03:40 PM
Shallow Bay's Avatar
Did you replace the front or rear O2 sensors?
Old 05-01-2006, 03:52 PM
the rear o2's.
Old 05-01-2006, 04:38 PM
2001NBMZ28's Avatar
Can you post the codes?
Old 05-02-2006, 04:27 AM
I'm guessing P0137 and P0157
Old 05-02-2006, 11:30 AM
yeah im pretty sure that was the codes. thanks
Old 05-02-2006, 12:54 PM
2001NBMZ28's Avatar
I'd have the codes read again to be sure they told you the right bank(s)/sensor(s). That's why I asked about the codes - just to doublecheck.
Old 05-02-2006, 03:21 PM
I had it checked twice, it was sensor two in both banks. Thats what kind of confused me...so im just thinking if it keeps acting up im just gonna try to put mil illiminators on the rear when my ses light is off and see if that keeps it off.
Old 05-02-2006, 03:56 PM
2001NBMZ28's Avatar
Look up the diagnostics for those codes at www.gearchatter.com too.
Old 05-02-2006, 06:33 PM
2K2WS6TA's Avatar
It's the rears, just slap in some sims and be done with it, if of course there are no other drivability problems.
If your state doesn't have emissions tests (visual or sniffer) then get rid of the cats, sounds like they are going bad, and aren't cleaning the exhaust like they should
Old 05-02-2006, 07:04 PM
Will the sims make my car run alot better? I live in fort worth, texas were its really hot and it seems on hot hot days my car dont run as good but once the weather starts cooling down I can tell a world of difference.
Old 05-03-2006, 01:33 AM
No it will only get rid of the SES light. The rear O2 sensors only tell the pcm whether or not the cats are functioning properly.
Old 05-03-2006, 01:40 AM
Also, is it possible you received two bad O2 sensors? I would take them back and have them replaced under warranty and then go from there.
Old 05-03-2006, 03:49 PM
I dont know whats goin on. This is the third day straight now and my ses light hasnt came back on and Ive been punchin it every where to see if I could get it to come on. I dont know what the deal is, im still gonna throw me some mil eliminators in the rear.
Old 05-23-2006, 12:17 AM
02 BLK WS6's Avatar
If you are still f'ing with this try cleaning the MAF with carb cleaner. PM for more details. I have p0137&p0157, cleaned the MAF and it runs like a raped ape.
